clutch types
flyboy2610
clutch types
Post by flyboy2610 »
I need to know what the difference is between a standard clutch and a diaphragm clutch. Is there any way to tell without pulling the tranny?
I don't think I am going to get the 4spd swapped for an automatic this spring after all and I need to get a new clutch. The parts books list two different styles and I don't know what my '68 F100 has. :?
Any help would be greatly appreciated. Thanks,all! :)
lobuck76
re: clutch types
Post by lobuck76 »
I never heard of a diaphram clutch, surely they don't mean hydraulic like the old chevys had. :hmm:
'71 F-100
flyboy2610
re: clutch types
That could be. The parts books list two different types. I gues I'll just have to wait till I pull the tranny and see what's in there.
Thanks for the reply, though.
68F250
re: clutch types
Post by 68F250 »
I didn't know you could get a diaphragm clutch for our year trucks, the original ones were the Long-style or standard. Would the throw-out bearing be the same?
You'll have to hear from the manual guys, I don't know how much you can see thru the bellhousing where the fork is.
lobuck76
re: clutch types
Post by lobuck76 »
So , is a diaphram clutch a hydraulic clutch?
'71 F-100
68F250
re: clutch types
Post by 68F250 »
Oh, no it describes the type of spring in the pressure plate. I was gonna try to describe the two but a picture is worth... well you know. Here's a link showing the different types, on top is a diaphragm style and the 5th one down where it says "older style" is the Long style with the three fingers.
http://www.babcox.com/editorial/bf/bf110218.htm
flyboy2610
re: clutch types
Thanks, 68F250.
That helped. I guess I'll have to wait and see what's in there to know what to get. The LMC catalog refers to it as the "optional diaphragm type'" and lists one for the 352, 360, and 390.
DuckRyder
re: clutch types
Post by DuckRyder »
I always thought they were interchangeable AS AN ASSY :?
:hmm:
Faithful Old Road Dog
re: clutch types
Post by Faithful Old Road Dog »
I haven't had to change the clutch in my highboy yet. When I do, I'll be looking up a Centerforce II clutch. I'm sure they'll have one for the FE. Centerforce is a diaphragm design with weights. Clamps down on that disc hard without the added heavy foot pedal pressure.
mont974x4
re: clutch types
Post by mont974x4 »
Now that's a thought. Thanks, Faithful.
I was looking at those in LMC as well.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
DuckRyder
re: clutch types
Post by DuckRyder »
mont974x4
re: clutch types
Post by mont974x4 »
hmm will that work on my 390?
I think I need a flywheel too tho. :hmm: I think I'll pull my inspection cover today and have a look around.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
DuckRyder
Re: re: clutch types
Post by DuckRyder »
mont974x4 wrote:hmm will that work on my 390?
It should, its listed as an FE application 68-75 among others.
I'm sure Summit would have the Flywheel as well.
shrektruck
re: clutch types
Post by shrektruck »
Mont,
Don't know how well versed you are in clutch work so I'm throwing this out "just in case"
Don't dare replace that clutch without at least resurfacing the flywheel.
Please don't be mad, I've seen folks do it and wonder why their brand new clutch still sucks.
mont974x4
re: clutch types
Post by mont974x4 »
:lol: No problem Shrek....I learned that lesson the hardware years ago...but a lil reminder now and again never hurts. :shh:
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
