volt/amp gauge- useful?
- Fake Name
Yes, I know they can be helpful. But in my many (many!) years of driving many different cars, I've never had a single instance of actually using a volt or ammeter.
Here's the decision: I want to use a billet instrument cluster, but it only has room for 4 gauges other than the speedo and tach. The usual lineup is fuel, water temp, oil pressure and ammeter.
I hate ammeters, I'd much prefer a voltmeter. But I'd really like a tranny temp gauge. I don't want to have another gauge scabbed onto the dash with an under-dash bracket.
People often cite a low voltage or bad ammeter reading to indicate a thrown belt and loss of water pump function. But that's what the temp gauge is for.
Am I missing something? Am I an idiot?
fn
fn
re: volt/amp gauge- useful?
A broken alternator belt isn't going to cause an engine to overheat, unless it's the only belt on the engine (also driving the water pump). I'd think you'd be way better off with a good voltmeter than a tranny temp gauge. You're more likely to have charging problems than an overheated transmission, IMO.
- Fake Name
Well, it's probably true a charging system is more likely to present problems. But not expensive problems that might be avoided via early detection.
I need to be clear- this is the internet- I''m not itching for a fight, but I need to understand your rationale...
thanks!
fn
thanks!
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
2011 KTM 990 ADV
2003 KTM 525EXC
- 68F250
How about a vacuum gauge?
Barry
Hmmm...well, I'm not saying a transmission temp gauge wouldn't be nice to have, I just don't think it's as important as a voltmeter, simply because as you say "...it's probably true a charging system is more likely to present problems".
My rationale isn't really based on anything more than my own preference, so take that for what it's worth. Very few vehicles ever produced ever came with a transmission temperature gauge, mainly because they don't tend to have problems, and I'd think that as long as your truck at least has a factory cooler and the fluid level is where it should be....and you're not trying to tow a house...you're not apt to have problems with a transmission. However, since I always say "I'd rather have it and not need it than need it and not have it" I think I'd try to find a way of incorporating both. Leave the voltmeter in the panel and maybe find a way of incorporating a small warning light in the panel (kinda like a high-beam indicator) that would be hooked up to a sending unit in the tranny, to tell you when/if the tranny temps reached a certain level.
Just my
Just my
- Fake Name
Well, by the time a charging system idiot light comes on it's too late...whatever problems your system was having (that you might have been able to catch early with a voltmeter) have gotten worse. A tranny temp warning light sending unit can be tailored, so at least with a warning light for that you'd have some kind of early-warning system.
Considering what you're building your truck to do (and where you'll be doing it), I agree that a tranny temp gauge might be wise. However, I also think the voltmeter should be included....so maybe you could find (or construct) a different panel where you could include both?
- Fake Name
Yes, I could. But I'm LAZY, and my fabrication facilities exceed my demand for quality.
And, really, I just don't think there is room on the standard panel for five gauges. Have a look here:
http://www.fordification.com/forum/download.php?id=129
this guy did a great job, but I'm still not seeing the available space.
I am open to suggestions....
fn
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
2011 KTM 990 ADV
2003 KTM 525EXC
You could always use a gauge with a slightly-smaller diameter. Look at the factory F600 panels...those gauges are only 1.5" instead of the 2-1/16" gauges being used in the panel you linked to, and they're plenty large enough for a driver. Or I think even with the larger gauges, with a little creative positioning you could fit 5 in there.
So would adding a small underdash gauge pod be out of the question?
- Fake Name
Hate underdash pods. Yes, I might have to use one, or maybe one on top of the dash.
I'm lucky to read a 4" speedo or tach, with my eyes. Progressive eyewear still does not help these old eyes. I can see the traffic (don't worry!) but I want BIG gauges.
Maybe something like a pillar pod, be it ever-so-ricer like.
fn
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
2011 KTM 990 ADV
2003 KTM 525EXC
- Fake Name
- 72hiboy4x4
I just had a problem with the charging system on my boat a couple weeks ago, and was able to catch it before the boat was, literally, dead in the water.
ended up the charging system had a short in it, and started dis-charging the battery while running. But thanks to an early warning from the guage, I was able to get it on the trailer before it died completly. I think an ammeter is worth its weight in gold.
I tow (OK used to tow) a lot of heavy stuff, but never saw the need for a tranny temp guage. And that was in the NV and AZ heat.
Its good information, but rarely actually needed.
