67' update...
zakt
67' update...
Post by zakt »
Getting ready to pull the frame out from under the 67'. Just debating where to put the supports so I dont tweek the body and cab. Its now on the little jackstands with all the suspension removed.
Todd
1972 Ford F350 crewcab
customcrewcab
Post by customcrewcab »
i think you need bigger jackstands :eek: :wink:
72hiboy4x4
Post by 72hiboy4x4 »
are you separating the body and bed? I'd just run a couple 4x4's under each and put the sheetmetal on those. easy and quick.
zakt
Post by zakt »
I thought about putting like 4x6 under it but Im thinking it might wobble or one bump and away it goes?
72hiboy4x4
you could build a roller stand like I did for my cab, then you could roll it around the shop or outside to work on it! Or bolt the 4x4's right to the cab mounting holes
spartman
Post by spartman »
That's a nice little setup you have there mike.
72hiboy4x4
not bad for a little bit of scrap and junk laying around, eh?
I may have to auction it off here when (IF) i ever get this cab done! :lol:
jor
Post by jor »
That's a great solution, 72. I'm keeping those photos for future reference.
jor
71 LONG BED
Post by 71 LONG BED »
Nice big garage! My LWB '71 barely fits in mine. A C/C, forget it! :D
John Member #1549
Image Image Image
zakt
Post by zakt »
We actually look for houses with the longest garage in the area since that was when I had the 67' and was going to start it as a project. The side the 67' on now is 22' and the side where the jack stands are on is actually 24' :D
71 LONG BED
Nice!! Lots of room. :thup:
John Member #1549
Image Image Image
zakt
Post by zakt »
only problem now is the garage door is to low only 8' door. So most likely will be building another garage with 10' doors.
71 LONG BED
Good idea. You don't want to get the truck back together and find out you can't get it out of the garage! :lol: :lol:
John Member #1549
Image Image Image
