vinegar
vinegar
so it makes penny's really bright. would ic remove calium build up from a float bowl?
69 F-100 2wd 360 cid C6
- heep70
What about shower cleaner. CLR I think it is called.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 390Nut
Dunno about that, but I've been told it cleans up hard, semi-ridgid plastic well. I don't know the proper technical name for it, but I'm referring to the black stuff you might see as a fender liner on newer cars, the inner-rear fender on many sport bikes, wire ties/snap clips, the vent assemblies on our trucks, stuff like that.BigRedTruck wrote:so it {vinegar} makes penny's really bright. would ic remove calium build up from a float bowl?
Another thing that cleans up pennies really nicely? Taco Bell hot sauce. The acids in it shines them right up! (makes you wonder what it does to your insides when you eat it! )
`69 F100 390 4spd driver
- Dropped 68
re: vinegar
For what it's worth, a buddy of mine rebuilds a lot of bikes, primarily trail 70's. And when he gets a really corroded carb, he soaks the bowls in CLR, and it works well in getting them looking new.
Charles
http://www.fordification.com/galleries/ ... ?cat=10451
http://s111.photobucket.com/albums/n146 ... =#imgAnch1
Build, Destroy, Rebuild!
- Dropped 68
re: vinegar
For what it's worth, a buddy of mine rebuilds a lot of bikes, primarily trail 70's. And when he gets a really corroded carb, he soaks the bowls in CLR overnight, and it works well in getting them looking new.
Charles
