front axel
- ak-1970-360
front axel
how do i id the axel in my 70 f100 4x4. i have looked for the dana 44 markings but i cant find anything. also is their any way to know if my truck that a posi rear?
thanks
thanks
- willowbilly3
re: front axel
If the truck is original, all that info would be on the ID tag. The front axle wouldn't be anything but a 44 as far as I know but look on the reinforcing webs on the center section and you should find a 44 cast into it. Check your rear end for posi by jacking up one back wheel and putting it in neutral 2wd. If it is posi you can't turn the back wheel you have off the ground.
- ak-1970-360
re: front axel
i checked for the markings on the webbing and i couldnt find them.
- heep70
re: front axel
Your frontend will be a light duty (smallball) closed knuckle open diff Dana 44. Not positive on the R&P size.
As far as checking for a posi in the rear, willowbilly3 explianed the way.
Or you can also lift the whole rearend, spin one side and if the other spins the same way it has some sort of posi in it. More then likely a Trac-loc.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
re: front axel
or you can do a burnout and see if you leave 1 mark or 2
this is how i found i had a one legger
- Rockcrusher
Re: front axel
Assuming your running gear is stock, the front axle is a high pinion Dana 44 with open knuckles. Ring gear size is 8½". All factory front axles were open differential. The upper left web behind the tierod should have 44 or 44A cast into it.ak-1970-360 wrote:how do i id the axel in my 70 f100 4x4. i have looked for the dana 44 markings but i cant find anything. also is their any way to know if my truck that a posi rear?
thanks
Rear is most likely a 28 spline 9" although there is a very slim chance it could be a semi-floating 19 spline Dana 60 (9¾" ring gear).
As someone pointed out, jack up the rear (or front) and turn one wheel by hand . . . If the other wheel turns the opposite direction, you have an open differential.
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
- ak-1970-360
re: front axel
i have a 9 inch in the rear i know that. i just need to get it jacked up and do the tests.
re: front axel
I thought high pinions came in like 76 and later trucks.
- heep70
re: front axel
Me Two
Greg
- Rockcrusher
Re: re: front axel
So far as I know, all '68-'79 F-100 4X4's had a high pinion, open knuckle, open differential 44 when delivered from the factory. If any of you guys have a low pinion from those years post up a pic and the BOM.Faithful Old Road Dog wrote:I thought high pinions came in like 76 and later trucks.
Rockcrusher
- morganater
re: front axel
LOL! Go do some brodys and/or burnouts and see how many tire patches you leave. This is also how I found out I have a peg-leg. And also how I found out motor mounts really matter, LOL.
94 Jeep I6 Back-up vehicle
reppin' AK
reppin' AK
- ak-1970-360
re: front axel
ya motor mounts really are important. well i did some powerbrakin today and i left doubles untill it got goin really good in 3rd. does it take talent to powerbrake a manual and get it into 3rd.
know i feel sorry for my truck because it really isnt set up for that kind of driving
. well ill make up for it with the new floors i ordered today from LMC.
