Starter not disengaging
F10YRB12118
Post by F10YRB12118 »
Does anyone have an idea why my stater will occasionally not disengage when starting.
When this happens the engine will not turn off even with the key turned to the off position. The only way to stop the engine is to pull the pos cable off the battery.
This is an intermittent problem so far.
Does anyone have an idea what might be going on.
Sean
1942 Chevy Truck, 1.5 Ton, G503
1967 F100 352 LWB Custom Cab
1969 Bronco Wagon 302
1972 F100 360 SWB 4x4 XLT
1972 F250 360 LWB Parts Donor
1973 F250 360 LWB 4x4 Donor?
1979 F250 460 Parts Donor
splavin90
re: Starter not disengaging
Post by splavin90 »
might need rebuild/ or some greese.
i know that on reproduction starters, they have white lithium greese caked on the starter gear
69 F100 81' 302 / 73' fmx
heep70
Post by heep70 »
Is your soliniod sticking? Sounds like something is not cutting the power off once the truck is running. May even look at the ign switch.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
kid
Post by kid »
The solenoid is stuck. That is why the engine won't shut off. The coils is fed from the terminal on the solenoid and bypasses the lgnition resister wire.
68F250
Post by 68F250 »
Yep, starter solenoid.
Barry
F10YRB12118
Gentlemen,
Thank you for all your help my starter issue.
I have a back-up solenoid that I might try to do a direct exchange. maybe that might help.
What do you think about replacing the Starter Relay? Might that be a cause as well?
Yours,
Sean
kid
Post by kid »
This is a ford we don't have starter relays until much later when we started using solenoid on the starter type starters. Only the Solenoid on your truck will cause both of those problems you described.
P.S. if you reverse the 2 small wires the truck will crank everytime the ignition is in on but will not start.
F10YRB12118
Boy, don't I sound dumb.
I've been reading my new book, Haynes Automotive Electrical Manual (for Dummys) and just learned the difference.
Havn't been home long enough to get to the garage and my beloved 67. But as soon as I do, I'll be replacing the solenoid.
Thanks for all your help
Sean
67highboy
Post by 67highboy »
yep starter sol.
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
F10YRB12118
Replaced relay with new/old one from the pick-a-part yard and starter works every time like a charm!
Now if I could only get my brake lights, and turn signals to work. Thats the next big project.
Thanks again for your guidance and assistance.
Sean T. Malis
Sean
