Pics of progress
- neoxman
re: Pics of progress
Looks great! I might do this too now... except, I don't see how you got those wide frame rails under the cab... how'd you do it?
- SmokeyBear
It really depends on the size of the hole. On the side trim I just welded it up. On the mirror holes I used a bolt and welded it in then cut off the excess.rjewkes wrote:Not too shaby smokey. Question on trim/Mirror and bullet Holes, Would it be easier And use less wire to tack in a bolt and then grind it down or is that still weld/wire intensive?
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
72 F-100 Ranger XLT
- SmokeyBear
Re: re: Pics of progress
The only thing I had to do was notch the floor brace that runs across under the seat where the frame goes and notch the rear of the cab, you can actually see that in this pic...neoxman wrote:Looks great! I might do this too now... except, I don't see how you got those wide frame rails under the cab... how'd you do it?
70 F-100 XLT
72 F-100 Ranger XLT
72 F-100 Ranger XLT
- SmokeyBear
- Sharkdance
Im not a big fan of lowered trucks but I gotta say that your truck is goint to look awsome! And ride good too.
did you notice the drivetrain bein higher up in the body? Tranny tunnel/driveshaft tunnel especially? I want to do my floor if possible, as its a basic custom job, more so than other things It needs, but I dont want to do it now and have to RE-do it because of clearance issues. I may need to just get the chassis swap done first as the truck isnt at risk to the elements of weather right now.
Hope to see some more updates soon!
- SmokeyBear
- 69F110
- binder56jd
that's good work smokey
now serving #235
now serving #235
- binder56jd
smokey- i 've been thinkin' 'bout this for a day or so and my conclusion is that you rate a 9.75-- i ain't never seen a 10-- 'cause that'd be perfection- what u have done with what u have is a very good job-- we don't have a hat's off moticon so how's
now serving #235
now serving #235
- SmokeyBear
The actual swap was pretty basic, no? You said only a few things had to be made. Rear mounts for the cab, but tranny mount can be reused/drilled to match tranny mount? I am really looking into doing this after the motor is rebuilt and back in the truck. I want to drive it for a few weeks, and then park it at my grandmas, and do the swap that way, so I can do the frame how I want. Full reinforcement, hydros, wheels, powdercoat...all that first. Get it mocked up/cut/notched and all that of course so everything mounts nicely when done.
