didnt know where to put this but. Wipers?
A_G
Post by A_G »
anybody know how to get the wipers to work. no smartass answers.
I cant seem to find the wiper motor. With the ign on. they still dont work.
Anthony
"The happiness of a a man in this life does not consist in the absence, but in the mastery of his passions"
~Alfred Lord Tennyson~
Caterpillar Diesel Haul Truck Mechanic
72hiboy4x4
Post by 72hiboy4x4 »
Wiper motor is up underneath the dash behind. Above the heater box.
since you don't want a smart-ass answer, I can't help you with whats wrong.
Like asking basic things like.....
is the fuse blown?
is there power at the switch?
If you jiggle the arms, do they start working?
cause that might offend you. So I won't ask.
A_G
re: didnt know where to put this but. Wipers?
Post by A_G »
well on other umentionable sights. Youd get an answer like
"turn the ign on" i didnt wanna hear an answer like that. or "turn wipers on"
you know.
Ill take a look tomrow.
I got ALOT of work to do on this thing. End of january. On the road again.
Jake11
Post by Jake11 »
Try tappin the wiper moter with a screwdriver handle. When it starts
let it run for a while. 8)
trukcrazy
Re: re: didnt know where to put this but. Wipers?
Post by trukcrazy »
A_G wrote:well on other umentionable sights. Youd get an answer like
you know.
A_G,
Don't confuse this site or the people on it with any other site. If you ask a legitimate question, you will get a straight answer. That's not to say some of us won't poke fun at you but that will be the price you pay for the answer you seek. Ask your questions and expect answers with a little fun mixed in. Everyone started somewhere just like you. Was this a long enough response for you (part of the fun)? Take care , John. :thup:
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
Jake11
Post by Jake11 »
Well said, T/C.
We all here, will help ya. I will try. They help me and all the other folks
that ask. I may post too much on here but I keep coming back. I hope
you stay a while. Share what you know. :)
A_G
Post by A_G »
i know its a different site. I love it.
But even i weould reply smartass to the same question. i was trying to avoid it.
Anthony
i reply like that sometimes. i i am wrong when i do it. it is because i am on here to much and i get itred of the same old questions sometimes. i haven't done it in a while i dont think but if i have i am not tryign to be rude or run someone off. i'm just getting to be a grumpy older man.
A_G
Post by A_G »
well i searched around and didnt find anything. I actually used the long lsot acient technology also known as "the search button"
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
If the above suggestions don't work (tapping on the wiper motor body with the switch on, trying to manually rotate the motor), then the first thing I'd do is first make sure the wiper switch is hooked up (just to ensure the connection didn't come loose), and then I'd check for power with a multimeter, both at the switch and at the wiper motor's harness hook-up. Check for continuity between those two points as well.
Wiper motors hardly ever go bad, so I wouldn't immediately jump to conclusions that it's bad.
jor
Post by jor »
Here's a diagram that shows where the motor is and also a photo of the motor. One word of caution: If you start messing with that motor, make sure your fingers stay clear of the wiper drive arms. If the motor starts and your fingers are caught, it will chew them up.
jor
flyboy2610
Post by flyboy2610 »
Geting to the motor is a lot easier if you pull the instrument cluster out first.
jzjames
Re: didnt know where to put this but. Wipers?
Post by jzjames »
A_G wrote:anybody know how to get the wipers to work. no smartass answers.
We got ya covered A G. A little tounge-in-cheek and local color is good.
If your wiper motor turns out to be toast after youve done your checks-(lube and grease the bushings and pivots), let me know, Ive gotten an extra one off ebay.
71 LONG BED
Post by 71 LONG BED »
Did the mice chew up any wires? For some reason they like to eat wire, must taste like cheese or something. :o
If the wires aren't chewed, they might be dry rotted. Some food for thought...
John Member #1549
Image Image Image
Tim P.
Post by Tim P. »
well put some of the wiring in theses old trucks is pretty cheezy especially when its been aged 30 + yrs :lol:
