how to engage
Moderator: Doug Comer
- cathynkeith
how to engage
ok, I'm dumb here my Tahoe goes into 4wd with the push of a button.
This 71 4x4 I do not know, I locked the hubs, pulled the handle back but the front tires do no engage.
When I drive forward, I can feel/hear the transfer case engage.
any suggestion?
any suggestion?
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
re: how to engage
Did you try 4 hi or just 4 low? If the hubs are in it should engage I would think. Are you sure the wheels are not engaged? maybe the shifter linkage is way loose and not letting it engage all the way.??
re: how to engage
also check and see if you have a drive shaft. Ya never know!!
If you hear it though I bet you have one.
- cathynkeith
re: how to engage
yep have shaft, the shift knob has been replaced with a t handle, do not know the pattern.
1969 f100 flareside
1969 f100 flareside
re: how to engage
If its the original transfer case it should be all the way back for 4-wheel and all the way forward for 2-wheel, no hi or low. The way I always try to engage is to lock the hubs first and then pull the lever back. If that doesn't work I would check the linkage first like was said earlier. Doug
Does it have a body lift? I owned a highboy with a 3" body lift and the hole in the floorboard wasn't big enough to let it shift into 4lo. If it's a dana 21 case, check under the truck, it may have snapped off and be laying on the ground under the truck. OK, they're not that crappy, but definitely not a real winner.
- Clarko
- 69F110
- cathynkeith
re: how to engage
thanks for the input guys, I took it to the muffler shop this am, going to let them put headers on while I'm out of town, leed mechanic drives realy nice lifted 4x4 bronco said he would look at it and he had some hubs I could have just cover labor. I like them deals.
1969 f100 flareside
1969 f100 flareside
- Clarko
