D60 rear to D60f
Moderator: Doug Comer
D60 rear to D60f
Can a dana 60 rear be built into a dana 60front?
re: D60 rear to D60f
Yes, Christian Hazel from JP Magazine did one a few years ago("Hazels' Sixty"). Started with a Dodge rear and put all Crane C's and knuckles with all the bling. Came out to right around what you would spend on buying a Dynatrac Front 60. Lots of work, but can be done.
67 HiBoy - 390/435/TS'd205 HPD60f/FFD60r welded 3.54's 36x12.50x16 TSL radials
50 Willys P/U (project) - 302/435/205 FFD60r
- Clarko
Good point. I really don't understand why anyone would spend as much to turn a rear 60 into a front axle as a dynatrac piece would cost. The dynatrac stuff is top notch. A ******* low pinion 60 front made from rear parts is not worth a whole lot.
