swapping from C-O-M to C6
What all do I need to convert my truck(1965 f250 w/390) from a cruis-o-matic to a c6?
![Laughing lol](./images/smilies/icon_laughing01.gif)
- 67F250CS
re: swapping from C-O-M to C6
I did this very same thing to my 67. The bellhousing is thicker on the com like 3 times as thick, so shorter bolts are needed. I also had to use the front half of the donor truck driveshaft and the back half of my original. Also I just pulled the speedo cable out of the donor truck and switched the plastic gear onto my original speedo cable. My C-6 has the inner type mount gear. There are outer and inner types. Mine had a small metal clip on the tip and I just had to pull it and slip the new gear on and push the clip back on.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
