Starting problem???
Locked
jokqs
Starting problem???
Post by jokqs »
I have an issue w/my engine turning over. One day I started it she was running then suddenly turned off, to not start again. It got cold after sitting for a couple of days, then I jumped her and all she did was turn and turn, not start. After turning for a bit, the battery started dying. I'm wondering if this is an alternator problem or maybe even as easy as a fuel filter problem. I'm in the process of getting some extra gas to drop in the carb to she if she fires to eleminate the fuel filter prob. Any help would do, thanx to all and :fr:
heep70
Post by heep70 »
Check solinoid or see if coil is getting juice.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
jokqs
re: Starting problem???
Post by jokqs »
Well today went out dropped some gas in the carb, jumped her and she fired back up for about 4-5 mins, then shut off again. Put some more gas back in the carb she fired back up, turned off, then continued to crank her then the battery started dying. Still a solenoid prob? How about fuel filter or fuel pump?
67F250CS
Re: re: Starting problem???
Post by 67F250CS »
jokqs wrote:Well today went out dropped some gas in the carb, jumped her and she fired back up for about 4-5 mins, then shut off again. Put some more gas back in the carb she fired back up, turned off, then continued to crank her then the battery started dying. Still a solenoid prob? How about fuel filter or fuel pump?
This is a good sign that the electronic are working ok. When you say ran for 4-5 min was that just idlinging or did you try to rev it up any? I am leaning toward a fuel sytem problem. Try to test the fuel pump output by pulling the line to the carb and cranking the engine over. You should get a nice shot of fuel about every second or so. Use a plactic or glass bottle to put the hose in or youll spray gas over everthing.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
jokqs
Post by jokqs »
Just installed a new solenoid....old won was all rusty and dirty. No luck...when I put fuel in the carb she fires up for a few seconds then shuts off....I got a new fuel filter, will install tomorrow, and work my way down the lines to the fuel pump.....thanx 4 the help will keep informed.....
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Since this problem seems to be fuel-related, and you've started a thread regarding this in the Engine section, I'm locking this thread so we don't have two identical threads going at the same time.
Locked
