Headlight Switch removal
DannyF
Post by DannyF »
I have a 1971 F-100 and I believe the headlight switch is going bad as the lights go off and on after they are on for a little while. Assume bad circuit breaker in the switch.
I have a new switch, but I'm having trouble getting the old one out.
I tried mashing the button on the switch hsg. in and pulling the knob out with no luck. It feels like it is still hitting the button.
Does anyone have any suggestions short of taking a hammer to it?
Thanks in advance for any suggestions.
Danny
1971 F-100
ICEMAN6166
re: Headlight Switch removal
Post by ICEMAN6166 »
Danny,try rotating the knob a bit,and wiggling up& down and if the knob on the top of the switch is pushed all the way in ,and it still hits then tug on the headlight knob some, i have had sticky ones before too.last resort is cut the shaft off with a hacksaw. i have a bunch of them if you have to do that and need a new knob.
the best thing to do to avoid these problems is to change the wiring so the lights work off relays because the factory wires are too small for the current flowing thru them.
you can do it yourself or there is a member selling them already to go
http://www.fordification.com/forum/view ... hp?t=17180
rjewkes
Post by rjewkes »
Sometimes you just need to push harder on the button as sometimes it feels/looks as pushed as it will go aslo you might try jiggling th the knob as you pull on it.
