What's the largest Cubic Inches a 360 can be bored out to???
- 71Ford
http://www.fordification.com/galleries/ ... p?pos=-851
71 XLT RANGER ->203,000+MILES/NOT REBUILT
99 GMC 4x4 Suburban, 94 Saturn 200k, 03 Chev Venture
- 68F250
re: What's the largest Cubic Inches a 360 can be bored out t
That's hard to say without a sonic check. I've seen one that was pretty thin with only a .030" overbore. It's best to bore as little as possible, just enough to clean it up. The problem is core shift and you don't know how much unless you have the block checked. Without going out on a limb, I would say .030" "should" be ok. Big overbores don't buy you much in the power department because the thin walls distort and cause blowby and rob whatever increase you were looking for. Thicker walls promote better ring seal.
- DuckRyder
68F250 is exactly right (as usual
Just thought I'd also point out, that a 360/390/410 are all the same block with the same bore. So if you are wanting to enlarge it, a 390 crank will make it a 390 and a 428 crank will make it a 410. You would also need the appropriate pistons and 390 type rods are much preferable.
- 71Ford
Thank You for the answers.
- cobraF100
71Ford,
I dont know where in Texas you are but I'm at Fort Hood and if you looking for a new FE I'm about to take mine out and put the New Stroker in..
The FE I have has about 1700 miles on it.
Chris
Never Forget Our Soldiers
