powered coated
- customcrewcab
powered coated
got my housing powder coat along with my brake hats. 60 bucks for the housing and 10 bucks for all the hats. i figured a good can of paint for the hats would have cost 6 to 7 bucks. hamered flat black.
- Blue Cloud
re: powered coated
Looks nice!
- GT-Racer
Looks real nice CCCab. I cant wait to see that thing when its done.
Did you ever have any luck with eliminating your vent windows? Let me know how that turned out.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
- customcrewcab
re: powered coated
heres another pic. it shows it alittle better. started getting the rotors and brakes put back on. still have some machine work to do to the fronts but should have them installed soon. moser 31 spine axles with a locker and 4.00 gears inside.
- customcrewcab
re: powered coated
haven't messed with the vent windows. i got it figured out just need to finish them up.
- GT-Racer
Re: re: powered coated
please keep me posted, I want to copy you on that one if you dont mind.customcrewcab wrote:haven't messed with the vent windows. i got it figured out just need to finish them up.
- rjewkes
Good work CCcab.
