The Ranger XLT @ Holley Ford Fest 2024 in Bowling Green KY After Missing HRPT 2019 and Power Tour 2021
- NATHANHASNORIDE
re: The Ranger XLT may run again soon.
Your engine is awsome!
NathaN
I'd push a FORD before I'd ever drive a CHEVY!!!!
- DuckRyder
Thanks,
Made a bit more progress today, and it actually moved under its own power from one side of the shop to the other.
Won't be two long now, being anal retentive is both time consuming and a lot of hard work too though...
- 69F110
WOW! That looks awesome. MAn I'm glad you kept that thing. Tat engine turned out sweet! That paint looks real good too.
Steve Davis
Pastor and U.S. Army Retired
Re: The Ranger XLT may run again soon.
Great progress from the looks of it. Quality work.
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
- 67mann
Re: re: The Ranger XLT may run again soon.
I guess this explains your avatar......Never saw this but, from most of your post... I wouldn't expect anything less
(not the Quote...the motor)
- DuckRyder
Wow... I forgot I even started this thread.
Unfortunately not too much progress has been made since this...
- Ranchero50
Even mountains eventually rise out of the mud.DuckRyder wrote:Unfortunately not too much progress has been made since this...
Progress is just like eating an elephant, taken one bite at a time.
- DuckRyder
Re: The Ranger XLT Gets a New (Griffin) Radiator.
So, First we needed a Radiator.
It seems like everything needs to be done quickly - I know of one Radiator shop, and last time I drove by they were putting like 24” wheels on a Camaro, so Confidence that I could drive the hour over there and get a working Radiator back in a reasonable amount of time was low, so this happened.
This radiator fit well except that the lower mounting flanges are a bit too wide and required some clearancing. I am not sure if this is because of the fact that my truck had some sort of A/C installed at same point and thus has some flanges and spacers that a stock truck does not have.
I will probably paint this black at some point.
- DuckRyder
Re: The Ranger XLT Gets a (Extang) Bed Cover.
Next up we needed to keep water from pooling in the bed.
An NPD cover just sags into the bed when it rains.
Perusing the NPD catalog they list the Extang bed cover for a Dent side as fitting Bumpsides as well, so lets give it a shot.
The Extang Clamp has 2 positions for the bows allowing the tightness of the cover to be changed
The bow in the low position
The bow in the high position
The snaps also can be installed to decrease or increase tension. I am not thrilled with the plastic snaps, or really the amount of plastic used in the frame, but it seems to work.
Fits pretty good.
Fits pretty good.
- DuckRyder
Re: The Ranger XLT Gets New (BF Goodrich All Terrain T/A KO2) Tires.
So we been doing some work around the house.
After several (ok like 10) full locker burnouts pulling stumps out of the ground the 2001 model GoodYear Wranglers are showing substantial cracking and produce not much but noise and dust when pulling (no traction)...
So the search is on for an appropriately sized tire.
Thanks to my friends at the dealer.
That should do it.
These things road forced at a low of 6 and a high of 12 for road force, this is quite good for a truck tire, particularly a fairly aggressive one.
Date codes were 2017 which is pretty fresh for a 15” tire.
Shame it will no longer do 3rd gear tire smoke...
She still cleans up OK.
Didn’t have time to powder coat the wheels... maybe next time.
That should do it.
- 67mann
like the cover might have to look into that and those look like some serious diggers
- popeyes71
Nice to see some pics of the truck! After some usage, keep us posted to how you like the bed cover and tires.
-Popeye-
1971 F-250 4x4 Highboy
- DuckRyder
On the bed cover:
It has been on there for a little while (several months) and I like it OK, if I had it to do over again I would probably go with the snapless version that lifts up, but it is much more expensive.
Rolling this one up neatly is not really a one man job, and getting it both tight and snapped in the back takes some practice.
I’m liking the tires so far, though pressure is a bit of a mystery. They are LT tires and seem to handle best with slightly higher than normal pressure.
Maybe I can get the other wheels painted and try them by next summer...
Wow your truck turned out great! I like the looks of that bed cover. Good work!
Kyle
Kyle
- Manny
You'll be happy with the KO2's duckryder. Got them on the dually and the 74' bronco. When its done the highboy will probably wear a set too. Wear good ride good. Don't know how well they smoke though. But with your 390 you will find out!!!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
