What else am I missing for tranny upgrade?
I have the 390 in my 72
OK I found a c-6 for $800...new at ck performance..will have to order bellhousing too?
I also found a B&M floor shifter for about $100
What do I need to figure on as far as:
xfer case
drive shafts
carb---I have an Edelbrock 600 but it's for the manul so no kickdown
crossmembers
besides the cinsideration for the above did I miss anything?
Thanks folks.
xfer case
drive shafts
crossmembers
Thanks folks.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
72 F-100 4x4
97 F-150 SCAB 4x4
- heep70
re: What else am I missing for tranny upgrade?
Are you bolting the t-case to the tranny? I am not real hip with the F100, but I believe they work that way.
The drive shaft lengths will change. Looks like you have thought of the obvious stuff.
How about the speedo cable length? You will also need a vac source for the modulator.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
The stock x-fer case is mated to the tranny.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
72 F-100 4x4
97 F-150 SCAB 4x4
- heep70
How about the linkage for the T-case? That will probaly change in length. ![Hmmm :hmm:](./images/smilies/icon_hm.gif)
Greg
Good call! I totally forgot.
Did these trucks come with a c-6 and x-fer case? Should I be able to find cross members etc. in a Junk yard? I think I'll have new driveshafts fabbed up...altho it'll be spendy.
What about a xmsn oil cooler and lines? I suppose I could buy a new one and just mount it in front of the radiator.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
72 F-100 4x4
97 F-150 SCAB 4x4
- heep70
Yes, I do believe they came with C6/205 combos. Like I mentioned, I am not real hip on the F100 4x4. I do know that came with T18 or NP435/205 combos.
As far as the cooler, I would definantly go with the external cooler like you mentioned.
Greg
- flyboy2610
Re: What else am I missing for tranny upgrade?
mont974x4 wrote:I have the 390 in my 72
The bellhousing on a C6 is integral with the tranny. Make sure you get the correct tranny for your engine.
Thanks Flyboy,
that would explain why they asked what block it was mating up to.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
72 F-100 4x4
97 F-150 SCAB 4x4
- willowbilly3
The 4x4 C/6 will have the 4x4 specific rear shaft. I am pretty sure they never put one in an F-100 with the small T-case although there may have been a few in 73-74. You best bet will be to find the 205 T-case from an F-150, ot even a 208 from the 80s. The 208 is an aluminum case and much lighter. They probably aren't as tough as a 205 but I haven't seen any problems with them in normal use and they are probably easier to find.
- '75-4x4guy
Now I might be wrong but I don't think ford put the dana 21 behind the C6 in the 1973-1979 ..All the 4 speed trucks up to about 1976 had the dana 21 then the NP 205 ..which kinda stinks but the 21 is a stout case when used in light duty application's ..All the 4x F100 trucks I have seen which have the c6 auto had the NP205
I think you will have better luck looking for a parts truck that way you can pull the cross member and drive shafts ...
Jon
