chop top has begun for "el diablo" update11-7-14
- customcrewcab
re: chop top has begun for "el diablo" update 7-2-
looks really good. i am glad you only took 3 out. i was thinking around 2.5 would be the max but 3 looks great. so you just have to pie cut the doors and windsheild frame to bring it back to the roof? just wondering about the windsheld and the angle below the cut. does the gasket take up the differance in the angles?
Hey mars the truck is looking really good. I noticed your are running some other type of gauges.
- marz68
Re: re: chop top has begun for "el diablo" update
layedout72 wrote:i like it marz, it doesnt really even look chopped! i bet someone that hasn't seen one before wouldn't look twice at it being a chop. That in my opinion is how it should be! I do like the radical chops though and if I ever do my truck, i may go an inch farther than you have.
Not to much and not to little it's just right.
- marz68
I'll find out when I get to the shop today....the glass guy is going to be there working on the front glass.customcrewcab wrote:looks really good. i am glad you only took 3 out. i was thinking around 2.5 would be the max but 3 looks great. so you just have to pie cut the doors and windsheild frame to bring it back to the roof? just wondering about the windsheld and the angle below the cut. does the gasket take up the differance in the angles?
- marz68
Thanks!gonzalo medina wrote:Hey mars the truck is looking really good. I noticed your are running some other type of gauges.
Yeah those are stock 89 mustang gauges...they are only there to cover the hole
- customcrewcab
- wt4speed#2
Marz, are you going to Reso 08? I am really considering driving out there. Not in the 72, but driving none the less. I figure if your guys from IF can do it to G-ville, we can sure as hell try! I really don't think it will cost a lot if (considering) if we have 4 people in the car. It's a 25 hour drive, should be like 6 tanks of gas each way. Hotel rooms are probably 100-150 for 4 nights. But between 4 people I bet we could get it done!
- jzjames
Very nice work and thanks for the pictures. So are you going to piece back together the rear window frame to give you a new configuration?
- customcrewcab
so did the windshield fit?
- marz68
All I know is that it's going to cost me $400 for a new glass and seal, the guy measured the opening and is working on it now.customcrewcab wrote:so did the windshield fit?![]()
- marz68
- customcrewcab
re: chop top has begun for "el diablo" update 7-09
looks good
so the roof is welded in? 400 not bad for new seal and windshield and having them both cut down an install.
- rjewkes
So its just a mild chop? not bad.
- marz68
