Np-435 oil
Np-435 oil
where can I find the proper oils requierments for the np-435 and a devoiced dana 24 for the Arizona climate I'm working on a 72 .
Bones Heal chicks dig scars and we have the best Doctors in the world.
- heep70
Haynes manual. 50LB for the tranny and 90LB for the tcase.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
90 wt is a pretty safe bet for both. My experience with 50 wt in a 435 is that it shifts great for a few thousand miles then you tow a heavy load a few hundred miles and the 435 bearings are gone. If you want better shifting and mileage than regular 90 wt gives go to synthetic gearl oil.
- 390Nut
re: Np-435 oil
They are all over ebay...
http://motors.search.ebay.com/1972_Truc ... fmtsZinsif
And in ebay stores as well:
http://search.stores.ebay.com/1972_Truc ... Z1QQsofpZ4
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- FrankenFord
got it thanks
Jon
No matter where you go there you are
1972 F250 4wd
http://video.google.com/videoplay?docid ... 1804&hl=en
http://profile.myspace.com/index.cfm?fu ... =188324618
1972 F250 4wd
- MaxKlinger
Do you have much experience with the Borg Warner T18? Would you say to also use 90 weight oil for the T18? I want to change the gearbox oil on my truck this weekend and I'm not sure what weight to use.averagef250 wrote:90 wt is a pretty safe bet for both. My experience with 50 wt in a 435 is that it shifts great for a few thousand miles then you tow a heavy load a few hundred miles and the 435 bearings are gone
I do have a factory owner's manual from 1972 but I thought maybe that 35 years of experience might have found something better than stock.
Tony
'05 Focus ZX4 ST - 2.3L, 5spd
- Redcap
