It poured down rain all day so I didn't make it to the farm for the engine parts and the cab floor section that was ordered Friday came in as the passenger side when I needed the drivers side so today saw the passenger floor get gutted and the replacement '77 bronco floor section get fitted and welded in. You know it's bad when you have to move the jackstand that's holding the cab up to remove rusted layers. The lower inner door post was rusted from the inside out and had to go as well. It actually made thing easier because I was able to use the kick panel and lower door post metal from the '77 and fit it all as one piece. It took a lot of time trimming away the metal until it fit correctly. I hate rust, I had a five gallon bucket of crap before the floor was removed and refitted. I didn't take any pics during the replacement and only two of it 90% finished, it was an ugly day. I'm going to do the other side tomorow.
The before pics...
I pulled half a window screen out of the kick panel hole once I broke away the bondo...
'New' cab floor. It's all one piece including the door post. I have to finish the welding and do a couple small rust repairs on the panel with the left over stock.
A plate hiding a ruined rusted cab mount. You know it's bad when a 1/8" plate rusts away and the cab droops when the fender gets unbolted.
Look a factory cab mount. I still have to drill some holes to puddle weld the lower panel to the door pillar where the vise grips are.
This is the sixth day of my seven off and I'm beat. I had hoped to have it running by tomorow, but I don't expect that to happen now, just too much to do to finish it off.
