C6 fluid and filter question
Galaxie64
Post by Galaxie64 »
I want to check and make sure the C6 behind my 400 in the '72 takes Type F tranny fluid. I would figure it does but want to make sure before I change it, also do they have a replaceable filter?
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
DuckRyder
re: C6 fluid and filter question
Post by DuckRyder »
They do have a replaceable filter.
If it has not been rebuilt with modern clutches it takes type F.
Type F will not hurt it even if it has been rebuilt with modern clutches.
Galaxie64
Post by Galaxie64 »
Excellent, Thank you
I doubt it has been rebuilt, it is starting to take some time to get into 1st and it has a leak so I am hoping it is just because it is low on fluid. I figured I'd just service it since it is low anyway.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
MaxKlinger
Post by MaxKlinger »
What year did they change over from Type F to Dextron III/Mercon? I remember I had to do some research to find out what fluid to use in the C6 in my '83 F150, I think it was type HG or something like that which was equivalent to Dextron-III/Mercon.
I found several resources that said NOT to use Type F in a C6, but this was for a truck more than a decade newer so it cuould very well have changed.
Tony
'05 Focus ZX4 ST - 2.3L, 5spd
DuckRyder
Re: re: C6 fluid and filter question
Post by DuckRyder »
MaxKlinger wrote:What year did they change over from Type F to Dextron III/Mercon?
1977,
But, Type F will still work in one with Dexron/Mercon clutches, all it will do is make the shifts harder. The old B&M "Trick Shift" was nothing in the world except Type F. However, if you put Dexron/Mercon in a type F transmission it will not work correctly, so for old Fords Type F is "safe".
We went trough this in great detail at the training center, but it was a long time ago... Basically the difference is how they react to friction, and the design and composition of the fibers is tailored to the fluid.
basketcase0302
Post by basketcase0302 »
DuckRyder,
That's some good information! Seems harder and harder to find type "F" too.
Basketcase
MaxKlinger
What would happen if you put Type F in a modern transmission? By modern I mean something which is a front-wheel-drive, transversely mounted four speed overdrive transmission. A good example would be the AX4N, used since about 1996 for the Duratec V6 and Yamaha V8 (Taurus SHO). Should one expect increased wear on the transmission? Firmer shifts?
Tony
DuckRyder
Post by DuckRyder »
MaxKlinger wrote:What would happen if you put Type F in a modern transmission? By modern I mean something which is a front-wheel-drive, transversely mounted four speed overdrive transmission.
I would not recommend that, I know it won't hurt a TH350/TH400 or a C4/C6. However there are some pretty specific fluids for "new" transmissions.
Type F and Dexron react differently to friction (F tends to "stick" the plates, and Dexron allows a little slip) so you could run into problems.
I haven't done it in a long time, but used to be if you called B&M and told them you couldn't find "trick shift" they would tell you, Just use type F, it is the same stuff. Now there are different types of trick shift.
MaxKlinger
Oh yeah, I have no intention of using anything but the recommended fluids in my vehicles. But I was just curious.
Tony
Tim P.
Post by Tim P. »
You could just use synthetic in any of them and be just fine as well.
