tranny cooler?
tranny cooler?
i have a factory made tranny cooler between my grill and radiator. as of now its not hooked up. i assume this would be a great area for it but how do i run the tubing from the radiator to it?
re: tranny cooler?
Bend some steel line, flare it and hook it up. Since your automatic should already have lines going up to the cooler built into the radiator, you only have to fabricate one line extension from one of the lines up to the cooler...essentially mounting it inline with the existing radiator cooler.
re: tranny cooler?
that sounds good. it looks like it has sit there for a while though. what would be a good way to clean it out?
Better use some cleaner thru it first then air dont need pieces of corrision getting in the fluidcraftsman wrote:spray some parts cleaner in it and then blow through with air compressor.
