tranny shift?
re: tranny shift?
its not wobbling, but it moves left and right when i move the driveshaft. i hope im explaining this correct.
re: tranny shift?
no bud, you have helped just fine. its just boggles my mind when i tighten the tranny down like it supposed to be it starts to act up. one thing i dont think i mentioned is when is when i was watching the drivetrain when my wife was shifting the column, i noticed when she shifted into drive the drive shaft would move then the rearend would engage. i hope this helps.
re: tranny shift?
i called my fathes inlaw just now and he thinks it might be the rear too. he said since the tranny wasnt bolted down i couldnt feel the play. now, do i need to change the gears or just let it be. will it get worse or stay the as it is?
re: tranny shift?
never rebuilt one before. what would you recommend? take it to a shop or is it a do it your self job?
re: tranny shift?
ford man, i thank ya for the help. i'll go take a better look at it in the morn. and let you know what i come up with. hotrod ford ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
re: tranny shift?
You should not have any movement from forward and back, you should have a little rotational movement which would be the gear lash and would be normal.
Fred
Fred
re: tranny shift?
it doesnt move back and forth. it does rotate though, but im not sure how much rotation is allowed.
re: tranny shift?
First, make sure your tranny is in neutral, then grab the rear U joint with both hands and try to rotate it. You should be able to rotate it slightly and hear a small clunk as it hits the ring gear teeth. Then try to move it towards the front and the back of the vehicle, you shouldn't get any movement. Then try to move it side to side, you shouldn't get any movement. Then get the wheels off the ground so you can rotate using the rear U joint. should turn the tires smoothly, if there is gear tooth or bearing damage, you will feel it. You will also feel if you have a brake problem. This will mostly eliminate the rear end as being a problem and you can go from there.
Fred
Fred
