I got the D70 rear out of the 1967 F350 2wd any ideas on what the spline count on that is 35??
Todd
D70 spline count ?
- zakt
D70 spline count ?
1972 Ford F350 crewcab
- two-bit
re: D70 spline count ?
Ya its 23, and only 23spline parts will work in that housing too!
I wanted to upgrade my D70 in my '72 to 35 spline.
NO LUCK. Shafts are different lengths, so you have to stick with '67-'72 shafts for that diff. Or get a totally different diff housing.
Lockers are available. It just might take you some time to find one.
Wow am i rambling
Two-bit
Wow am i rambling
Two-bit
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
- 72hiboy4x4
I heard when I installed my D-70 under my truck, that if its a 2-piece carrier, a (chevy)14 bolt locker would fit it. Haven't figured out if thats in fact true, but thats what I heard.
