Install C6 in place on 3sp on column
Can this be done with out cutting out center hump?
re: Install C6 in place on 3sp on column
Did they make a removable C6 hump? I thought they were all solid.
Yes it can be done. I have a 460 with c6 in my 71 F100. My F100 came stock with a 302 and 3 speed on the column. My center hump is the short one that is not removable. It does make it alot easier if the c6 you choose does not have the extra ribs running down the back side of the transmission.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Cdeal did your C6 have the ribs? Is it the older(FE)'s or newer 460 C6's that have the ribs?
Re: re: Install C6 in place on 3sp on column
I don't believe it has to do with the year of the tranny, but whether it's considered 'heavy-duty' or not. Here's a shot of my '70 HD C6:Texas69 wrote:Cdeal did your C6 have the ribs? Is it the older(FE)'s or newer 460 C6's that have the ribs?
Keith, how is your 460 build up going?
