I`ll try to make it quick, please bear with me. I don`t have a 67-72 ford truck, I have a modified 93 Explorer with a 1978 vintage dana44 up front and a mystery Ford 9 inch in the rear. Events have led me to believe it may be an old F-100 axle.
I came across these axles as the last owner found them, behind his garage on some property he bought. All that was there was a frame and two axles..
I rebuilt the axles and put them into my 4x4 project, seeming only to have troubles with the rear end, namely, the bearings and seals. Anyway I ran it for a while, but slowly pushed it more and more, then got stupid and snapped a rear shaft.
that is when my troubles started~
I cannot seem to find replacement shafts for this axle even though I brought the actual axles into the parts store. They say the measurements don`t add up, in other words they don`t exist!
What I know:
- Axle housing flange to flange measurement: 60.5 inches
- Big bearing (smidgeon over 3 inch outside dia.)
- housing is "old" or "banjo" style (rounder than later housings)
-Shaft flanges bolt up as 5 on 5.5
-shafts are 31 7/8 long (end to outside flange)
-shafts are 28-spline
- shafts had 11 inch Drums on it and 2 &1/4 inch shoes
- The mounting studs look like 7/16 fine thread and fit through 1/2 inch diameter holes in the brake backing plate. The fastening bolts are 3/4 inch size
*A large part of the parts store confusion seemed to be the equal length shafts. The shafts I have are the exact same length BUT one side seems to have not run into the carrier/locker splines as far as the other, with maybe 1/4 inch of spline running outside of it on one side, and fully seated splines on the other -so it could well be that the axle is slightly offset..
(it was the passenger side that is possibly short, although it was the driver`s side that snapped)
Finally, discussing this anomaly with another web wheeler has broght to light the idea that the 9 inch is from a 67-72 Ford F-100.
So being no stranger to specific automobile internet forums for enthusiasts I started searching 72 F-100 and found this site!
Thanks for looking, I hope someone can help out, SOMEONE has to know the answer! Let me know If I`m missing some info that will help out.
Gotta get back in action!
-James
