Dana 70
FLATBEDFORD
Dana 70
Post by FLATBEDFORD »
A friend of mine will give me his '86 F350 4X4 diesel dually dump. Is the dana 70 from the '86 a direct bolt in for my '70 F350? This one has shock mounts and may even be limited slip :pray: The last time I looked at the truck the springs and rear looked identical to mine.
My Photo Gallery
FORDification
Site & Forum Admin
Site & Forum Admin
re: Dana 70
Post by FORDification »
Well, I'm pretty sure the frames are different width, so you'd have to relocate the spring perches.
cooltoolguy
re: Dana 70
Post by cooltoolguy »
springs on the 86 should be wider too. 3 inch i believe. and like keith said u have to meaure the width of the perches. hope it works :thup:
put the diesel in the bump too :D
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
RedneckTexan
Re: re: Dana 70
Post by RedneckTexan »
cooltoolguy wrote:springs on the 86 should be wider too. 3 inch i believe. and like keith said u have to meaure the width of the perches. hope it works :thup:
A Diesel-Dump-Bump, that would be Awesome :rock: :thup:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
two-bit
re: Dana 70
Post by two-bit »
Spring perches are in a different location, you would have to cut off the old ones and weld on new ones to match your leaf springs.
It may also not be a Dana 70. Check and make sure it is, otherwise you just adopted a corporate full floater. Not horrible. But not as durable as a Dana 70.
The corporate full floater looks just like a Dana. Check the housing for the "70" casting mark. It should be on one of the side ears of the housing facing the yoke (driveshaft).
Check your flatbed rear diff. to locate it.
Then check the 4WD. 4WD may also have the tag on the rear diff. cover that lists the gear ratio.
if it says 4.10 its an open 4:10-1 ratio.
if it says 4L10 its a locker at 4:10-1 ratio.
Being its a Diesel, its prolly a 3:73-1 or a 3:54-1. A 4:10-1 would push a diesel pretty hard at 70 mph.
Good luck with it.
Two-bit
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
averagef250
Post by averagef250 »
What's a corporate rear? Ford used Dana 70's and sterlings. They look very, very different from one another. The sterling is a very well built axle and is an equal to the D70, some say better.
Seen a stock sterling with a spool hold up for years behind a 600 horse big block and 46" tractor tires in Oregon mud. Nothing wrong with them.
FLATBEDFORD
I'm gonna go have a closer look on the weekend. If he's giving me the truck, I suppose it would be worth taking as long as the neighbors don't mind another junker in the driveway. I don't think I'm going to get involved in putting the diesel in my bump. I'd be better off putting a new cab on the '86. I'll post more after I see it again.
My Photo Gallery
two-bit
re: Dana 70
Post by two-bit »
averagef-250, you are right. I was thinking about the full floater used in the 2wd F-250 in the eighties.
I forgot all about the Sterlings.
Sorry 'bout that :oops: :oops: :oops:
So many rear ends, so many different trucks.
Hard to remember.
Two-bit
averagef250
Re: re: Dana 70
two-bit wrote: I was thinking about the full floater used in the 2wd F-250 in the eighties.Two-bit
The 70 and the sterling were the only two axles used under F-250/F-350 pickups for most of the 80's/90's. The 250's used a good number of Dana 60's in the lighter trucks and Dana 61's in the heavier ones in the early 1980's until the sterling was introduced around 84/85. When the sterling came out they had two models: the full floater and the lighter semi floater. The semi floater was under the lighter GVW and smaller engine trucks, though a good many diesels came with them too.
FLATBEDFORD
I went to look more closely. I even brought a tape measure. There's no tag on the rear, but it does look about the same as mine.
The springs are the same. I measured the length, the width of the leaves, the number of leaves, and the location of the axle on the springs. The only difference is that the axle is wider from the springs to the backing plates. The frame on both trucks is 34 inches.
This truck also has the lower shock mounts that attach to the axles with U bolts. :thup: Rear shocks for FLATBED!!!!!
Here's a shot of the truck. I'll post more elsewhere.
My Photo Gallery
FLATBEDFORD
My Photo Gallery
averagef250
That's a heck of a good friend to give you a truck like that! 1 ton 4x4 diesel dumper with a hydraulic winch. WOW!
That rear is a sterling, not a D70. Notice the cast in "gussets" around the axle tube sockets in the center chunk and the diff cover looks nothing a dana axle.
It appears from the picture like it might have the variable rate proportioning valve setup mounted on the axle. That is a very, very cool setup to have.
FLATBEDFORD
What do you all think the axles on this truck are worth?
My Photo Gallery
averagef250
Likely $700-800 in decent shape. Some will say more, but the later dana 60 front axles are pretty common and dually axles are usually less desireable unless you find someone looking to convert thier single wheel truck.
FLATBEDFORD
Thanks
My Photo Gallery
