Snaggletooth 69 F350 Comes home.
kid
re: Snaggletooth 69 F350 Comes home.
Post by kid »
Blow by Blow plans.
Heads are now C8AE-Hs so I need to see what the specs are. If not good I am going to go after some older 352 or 406 heads.
427 Exhaust valves Manley Severe Duty Series Stainless Steel Valves
Valves, Exhaust, Stainless Steel, 1.750 in. Diameter, Ford, Big Block, FE, Set of 8
427 intake valves Manley Severe Duty Series Stainless Steel Valves
Valves, Intake, Stainless Steel, 2.250 in. Diameter, Ford, Big Block, FE, Set of 8
Roller Rockers with Hydraulic Power Beast Cam from Crower.
D3TE Block
Custom Crank and Rods from Crower.
I haven't decided whose pistons yet since with the special rod length the Piston pin placement has to move. I have had great luck in Drag racing FEs with Arias but in my Desert racers I used TRWs.
Zoom Clutch 11" , Overdrive in front of my NP435.
kid
Post by kid »
This is why I cut the fenders off and ground the bolt heads off.
This is why I have to move it already. The garage is not big enough.
oldbiker
Post by oldbiker »
:hj: :x :x :x I can't believe what I am seeing in the very first picture!! when I went to Mesa to pick up Johns F-250 I spent 1/2 a day trying to rent a tow dolly like that from U-Haul :hw: :hw: :argue: :argue: I told them I had seen truck on them before, they told me that a bump was to wide and I was outta my mind :box: :box: :box: I am gonna copy those pics and shove them up somebodies :eek: ...srry had to vent.............
theskytoucher
Post by theskytoucher »
NO matter how much you fight it they still wont rent you rhe dolly. the way to get the dolly is tell them it is for a small car and they will send you on your way!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
oldbiker
Re: re: Snaggletooth 69 F350 Comes home.
Post by oldbiker »
theskytoucher wrote:NO matter how much you fight it they still wont rent you rhe dolly. the way to get the dolly is tell them it is for a small car and they will send you on your way!!!
Yeah, I see that, but I now am the proud owner of a chincy tow bar I had to purchase when I got there. I had called made all the arrangements it was all good till I spent a small fortune in fuel to get there. :x ..I think I have had my last dealing w/U-Haul..I think I said that before and used Penske. Live & learn..sometimes :lol: :lol: Not gonna let those $@#$# ruin any more of my good nature :D
390Nut
Re: Snaggletooth 69 F350 Comes home.
Post by 390Nut »
kid wrote:My local machine shop say he has had great luck getting 360s with the backwards 105 on them to reach 4.25 bore.
Manny wrote:You know where the 352 casting is by the water pump. Well some blocks have a 105 right there these were heavier cast blocks with thicker walls and higher nickel content. If i'm not mistaken i think they were cast in mexico in the 70's like 360's mainly?? I got a 75' 360 105 block along with my 250 when i bought it.
:pop:
`69 F100 390 4spd driver
FLATBEDFORD
Post by FLATBEDFORD »
I thought you guys didn't have rust out west.
My Photo Gallery
