Is the axle ratio stamped on the axle somewhere? I've found the model, serial no, and us pat number on it but I can't find the ratio. the vin code says "27" "Dana 70 4.10 open differential" but my rear-end has been swapped with a junkyard rear so now I'm stumped
Axle ratios were never stamped on the housing, since the same housing was used for all available ratios. Pop the rear cover off and either count the teeth or look on the side of the ring gear, where the ratio will be stamped.
'67 F-100 2WD SWB ~ '69 F-100 4WD SWB w/7" chop ~ 1975 F-250 Ranger XLT Supercab Camper Special My '67 restoration video -> Posting and you!<-a MUST watch for all!!
