300 EFI Update w/ pics
FoMoCo
Post by FoMoCo »
Hey All, My 300 EFI came to a halt about a month ago. Summer is winding down and other small projects take priority. Especialy When the soon to be swapped 360 is running really nice. Here's some pics so far.
Disassembly and replacing a few gaskets.
Another disassembly
The no Sludge bottom end. The 89's title read 34,000 miles and it shows!
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
FoMoCo
re: 300 EFI Update w/ pics
Post by FoMoCo »
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
FoMoCo
Post by FoMoCo »
Basically all I've done is add new gaskets except the cylinder head gasket, walnut shell blasted it, then 2 heavy coats of PPG expoxy primer. I'm not planning on painting it at this point
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
TheEskimo
Post by TheEskimo »
Looks very nice
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
Blue Cloud
Post by Blue Cloud »
Lookin good! :thup: I've been thinking about a 300 in my next project. Maybe. :hmm: :hmm:
460 crew
Post by 460 crew »
Lookin very good. :clap:
lightning_msd
Post by lightning_msd »
are you stickin that in a bump? :D
Ranchero50
Post by Ranchero50 »
Go ahead and do the freeze plugs under the exhaust now too, They really like to rust out for some odd reason and are a pain to replace int he truck. Looks good and should run good. How are you going to do the return fuel line to the tank?
Jamie
FoMoCo
Post by FoMoCo »
I forgot to mention that this engine is going to reside in my 69 2wd lwb custom cab.
For the return line, I'm going to sandwich the sending units top plate with two sending unit block off plates, then solder in a 6AN male fitting. The OE fuel rail will be fitted with Russel brand Adaptors that will convert the ford quick connect to 6AN. Inbetween I plan on using braided stainless and a walbro pump. No hard lines.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
