Spent the day workin' on the CS
kaptnkaos
Post by kaptnkaos »
Spent the day tearing down the CS...
Got the steering column pullled so I can rebuild it with the
pwr steering shaft and paint before reinstalling.
Pulled the grille, bumper, and lower valence.
Only the two main rad support bolts left to remove support...
Pulling column
Column out
Rusted clip
Radiator support rust
(click on pic to enlarge)
The bad rust is only about the size of 1/4 of a dollar bill (or smaller)
I am debating about just cleaning the existing support up instead of replacing it... this is sorta what I have in mind.
1) Cut out the active rust to clean metal...
2) Use Eastwood rust encapsulator to kill the rest of the rust
3) Patch with sheet metal and fiberglass enpregnated resin
4) Paint
The floor pans also have a couple of small areas that could be patched the same way.
Anyone got any ideas or feed back ?
Thanks again,
KaptnKA 8) S
truckguy
re: Spent the day workin' on the CS
Post by truckguy »
Its looking good. Thats what I do, just patch the rusted out areas. But if had a good rad support I would use that, save some time and work.
Kyle
Image ImageImage
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
kaptnkaos
Post by kaptnkaos »
Hey Kyle...
I have another support... but it also has a rust through.
Depending on which one has the least amount of work to clean up, I might swap supports
I wanna make sure that the '71 support and the '68 are the same...
It seems I read that they would work but there was some minor mods needed to make the swap...
Anyone have any info on swapping a '68 rad support with one from a '71?
Thanks again,
KaptnKA 8) S
Finleyphoto
Post by Finleyphoto »
Check out the patch panel welding article in this month's Classic Trucks Magazine - Dec '07 Issue.
They use the patch panels to *repair* rather than *replace* the floor boards in a Bump.
By the way, which paint are you going to use on your column.
I've got one I should repaint and want to stay with the white.
Dennis
Check out my Photos on Webshots at...
The Whiskey Flats Farm & Implement Co.
http://good-times.webshots.com/album/560836732OwHRTB
basketcase0302
Post by basketcase0302 »
Alan,
I had a 1961 Ranchero, (had is the key word here) :cry:
Had to get rid of it when we moved here last year, (was slated to go on top of my D44 & narrowed 9" on top of some 44's). One bad 4 X 4!
The floorpans were done in fiberglass like you said above.
I was amazed at how long ago they had been done-VS.-the good shape they were in. :thup:
But like kyle said too, if I had a newer one I'd change it.
Hey... BTW I like your visegrips with the knurled handles! :thup:
What brand are those please?
kaptnkaos
Post by kaptnkaos »
Hey Jeff...
Thanks for the feedback.
I'm not sure what brand the vice grips are...
Master Mechanic I think... I got them at Ace Hardware here in town.
They come in two sizes. They work a little differant than regular ones.
I like them.
KaptnKA 8) S
