I have a '68 F100 short bed with a 360 3 speed manual. When I bought it the driveshaft was horribly bent, so I had a new tube put on it. When I tried to reinstall the driveshaft, the slip yolk only went in about 3" and stopped with a solid thud. I figured moving the truck with the bent driveshaft screwed something up in the transmission, so I pulled it and took off the tailshaft. As you can see from the photo, there is only about 3" of spline, while the slip yolk is about 6". There is a lip after the splines, so naturally the yolk won't slide on any further.
My question is, is this the correct slip yolk for my truck? I am guessing Ford didn't design it with half the slip yolk length sticking out of the tailshaft. I tried looking for a replacement slip yolk, but places like Rock Auto don't even list one for my application. I'm considering cutting down this slip yolk until everything seems kosher, then run it. BTW, the end of the splines is where the end of the tailshaft is.
Can anybody comment on what I have? Thanks.
Kris
![Image](http://works-power.com/shaft.jpg)
