I am using a 5 lug Dana 60 rear and may decide to go a different gear that I originally planned. If I can I want to use the Powerlock as its much stronger, then sell the Trac lock, but I cant really do much with either not knowing what they really fit.
From the picture below, I have a Powerlock 4 pinion posi, a Traclock 2 pinion posi, and an open diff.
When sitting on the bench, all seem a little different in where the ring gear sits. Danas use different carriers based on gear ratio groups and these parts have been mixed up under my bench since the early 80's, I have no idea what gear set was originally paired with the posi LOL
Does anyone know how to identify each carrier for its specific ratio, short of setting each one up to see how things line up?
Thanks in advance
