I have a parts truck that is a 70 Canadian Ranger XLT. I checked the tag to see what rear axle it had and the VIN tag said code 17 for axle. I have not found a code 17 for a 1970 truck. Does anyone have a good idea what the ratio is and if it is supposed to be a limited slip, posi, or open diff. I do know it is a Ford 9" housing in the truck now. Any ideas would be great. I am just curious now.
Also, I know this is off topic, but I found a box under the dash with date codes correct for the truck. It was black plastic about 3x4x3". It had 8 - 10 wires and a couple rubber hoses coming out of it. It must be factory or a factory add on of some sort. Anyone know what it may be?
Sorry for my curiosity, but I would like to know what this truck had.
Thanks,
Odball Axle ID Code
- Joshpow
Odball Axle ID Code
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- l1k2gadd
I still haven't found out what a Dana 44 rear differential looks like.
The '68 F100 Donor truck (that came from out west) that I have here came with a Dana 44 according to the door data tag on it.
Too many projects, too little time, but.. lovin' it!
2-1966 Mustangs (one 289-2V and one 200 6 Cylinder),
1-1990 7-Up 5.0 Mustang LX Convertible (second one),
1-1990 7-Up 5.0 Mustang LX Convertible (third one, for parts only)
1-1990 7-Up 5.0 Mustang LX Convertible (fourth one, best of the bunch).
1-1992 "FEATURE" 5.0 Mustang LX Convertible (only one)
1-1993 "FEATURE" 5.0 Mustang LX Convertible (one of the yellow ones)
re: Odball Axle ID Code
A Dana 44 looks just like a Dana 60, only a little smaller. If the rear cover bolts can be removed with a 1/2" wrench, it's a Dana 44. If the bolts require a 9/16" wrench, it's a Dana 60. Also, as fordman states, if it's a Dana rearend, the model number will be cast into the reinforcing rib along the bottom right of the housing. Here's a shot of my Dana 60's markings:
![Image](http://www.fordification.com/board/dana-id.jpg)
