axels
re: axels
A good swap though, is to swap the entire housing over from a dentside to e bump side. It lines the rear wheels up with the front and in my opinion looks 100 time better. I want to do this on mine one day.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- convincor
re: axels
wider wheels with more offset would be easier than the rear swap.
Not mine but planning on taking advantage of the narrower rear.
![Image](http://i101.photobucket.com/albums/m41/convincor/F100/dropped1.jpg)
68 Custom Cab Shorty, 390, C6, 9"-3.50:1 Currie T/L
"Still Plays With Trucks"
http://s101.photobucket.com/albums/m41/convincor/F100/
re: axels
No it doesn't. You can only fit a certain size tire in the wheelwell, regardless of the rearend width. With a different-width rearend, you'll simply need a wheel with a different offset to re-center that wide meat in the wheelwell.
- willowbilly3
re: axels
Plus you could get rid of the 67 brakes and wheel bearings for something more obtainable if you need parts like drums, and probably bigger brakes too boot. A good swap IMO and what about the perches? Why does that sound like such a big deal to everyone? If you can't save the old ones when you cut them off then go spend some coffee change and buy new ones. If you don't have a pinion angle guauge use a torpedo level and a protractor to measure the old one and set the new one the same before you weld them up.
- 390Nut
re: axels
That's provided you own a welder, and/or know how to use one.
Many people don't.![Cool 8)](./images/smilies/icon_cool.gif)
Many people don't.
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- Joshpow
re: axels
15x7 front and 15x10 rear Those are the magic numbers for my 72. The outside edge of the front and rear tires are now in line with one another. I like the look also. Only con is wet road. The 72 wasnever a wet road lover, but now it is a little worse. If anyone wants to see the results, go to the website in my signature.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- turk54
re: axels
I don't mean to hijack...well yes I do, but just for a minute. How much narrower is our rear end than the front? 1" on each side or 2" on each side?
I know I've read this on here before but I can't find it.
Unrestored 71 Bump, 4x2 LWB, 302, 3 speed on tree, 40,000 original miles
71 Torino 500 Halo, 302, Auto
![Image](http://www.fordification.com/galleries/albums/userpics/10423/fall1.jpg)
- cghstrojan08
re: axels
![Surprised :o](./images/smilies/icon_surprised.gif)
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
![Image](http://i9.photobucket.com/albums/a75/cghstrojan08/IMG_2236.jpg)
![Image](http://i9.photobucket.com/albums/a75/cghstrojan08/ford.jpg)
Member #1076
1968 F100 SWB 360
- AlleyCat
Re: re: axels
I believe the rear track is 3" narrower than the front.turk54 wrote:I don't mean to hijack...well yes I do, but just for a minute. How much narrower is our rear end than the front? 1" on each side or 2" on each side?
Clay
