tranny suggestions
shortbedCUSTOM
tranny suggestions
Post by shortbedCUSTOM »
well, I think my 4speed is on the brink of taking a crap. :x I've been contemplating going with an automatic tranny this time around. which tranny, the c4 or the c6, would be more at home in my '70? which one would be the easiest to swap in?
I have two c4's available to me but I don't think it would be too difficult for me to locate a c6. oh, one of the c4's only has about 800 miles on it and it's built right.
please help. :?
spartman
re: tranny suggestions
Post by spartman »
If you have a good C-4 and don't plan on pulling very large items go for it.
If you are looking for fuel mileage with an auto you might want to consider and AOD that has be properly rebuilt and has the updates for reliability.
As far as installation the two trannies I believe install the exact same way.
also check your yoke end to see if it is a slip on or bolt on. If it is a bolt on you will have to get a new yoke. Not to hard to do. Just visit your local junkyard
shortbedCUSTOM
oh, I was under the impression that the c4 and c6 were overdrive trannys. :oops: ok well, what AOD would you recommend and out of what vehicles can I find it?
spartman
Post by spartman »
Their are many versions of AOD.
I know that the earlier versions were not computer controlled and defenately need the updates done to them before putting behind your motor.
Any good tranny shop should be able to help.
YOu might want to do some reading here: http://www.becontrols.com/products/aodcat.htm
they seem to know what they are doing.
You can find the AOD's from just about anything from about 83-84 on up.
The website above can explain it better than I can.
Have fun
Nefarious67
Post by Nefarious67 »
I take it your truck is a small block. If its not, an aod will not fit behind a big block with out an adapter. From what I read aod's were pretty good transmissions. I have also heard taht the shifting is odd in the fact taht under a normal load it will skip a gear. 2nd or 3rd i forget. Aod's are controlled by a tv cable ( throtte volume ) and if not adjusted right will fry the transmission. Aode's are the predesesors to the aod's. Its just an electronically controlled version of the aod that is built tuffer. if you want the aode you will need a stand alone controller. If you have a big block engine then your limited to and e4od which is electronically controlled and you will need a stand alone controller also.
flyboy2610
Post by flyboy2610 »
And if you have an FE engine, the C4's won't fit it without a custom bellhousing. Can you say: :$$: :$$: ?
A C6 will fit but make sure you get a tranny made for the FE series.
A C6 made for a 429 or 460 wil not fit a 352,360,390,427, or 428.
cobraF100
Post by cobraF100 »
shortbedCUSTOM,
What Engine are you running :hmm:
Chris
Never Forget Our Soldiers
customcrewcab
Post by customcrewcab »
i have a 5 speed and a lakewood bell housing with a centerforce clutch forsale. i have 850 in the rebuild everthing replaced and and around another 600 in the clutch and housing. i need 600 for everthing. i am going to build big block for my 64 falcon now.
shortbedCUSTOM
sorry fellas, thought I had mentioned that. :) I have a 302 in it.
shortbedCUSTOM
Re: re: tranny suggestions
customcrewcab wrote:i have a 5 speed and a lakewood bell housing with a centerforce clutch forsale. i have 850 in the rebuild everthing replaced and and around another 600 in the clutch and housing. i need 600 for everthing. i am going to build big block for my 64 falcon now.
might be interested. how do you think this will act in my truck? what kind of 5speed is it? will it handle a heavy truck? I had thought about going 5speed before but a lot of people mentioned that I might not be strong enough for such a heave truck. enlighten me.
customcrewcab
i had it in my 70 short bed with a blower. it was a roller 302 with motorsports f cam and dart sr. heads. b&m 144 blower 8 pounds of boost. the only problem i had is that it like to take a rip the radator off it mounts and it hit the fan twice. then i made some heavy duty mounts. my truck only had 3.00 gears and didn't hook at all but it was still faster then a 2003 cobra mustang. here a pic of the motor in my car and a pic of my old truck.
GT-Racer
Post by GT-Racer »
what kinda five speed is it? truck style or close ratio like a mustang t-5?
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
customcrewcab
its a t-5 out of mustang with a higher gear set. its the kit that sells in the svo book. i don't remember what first gear is, i think 2.97. the kit makes it have the same gearing as a tremmec. it also has the upgrade output staft and upgrade world class t-5 parts. we also boxin the clutch fork.
shortbedCUSTOM
customcrewcab,
I'm very interested. pm me your # and I'll give you a call. I would like to talk more about it.
thanks,
Carlos
GT-Racer
Post by GT-Racer »
Carlos if you dont want it I may. Keep me posted. Thats what I want to do to mine.
