Dana 60 Axle Spacer
Dana 60 Axle Spacer
Help......!!
Due to a badly spun bearing in my original semi-floating Dana 60 (from my '68 F100), I recently swapped in a full-floater 60 (as well as the accompanying 8-lug front setup). But I wanted to keep the PowrLoc posi unit from the original semi-floating rear (since my new full-floater had an open diff). So I scrounged up the parts to convert to the correct splines, and now have the PowrLoc in the my truck, and the open diff in the "parts truck".
Everything was great until I noticed that I had a LOT of end play in the axles of the semi-floater (now in the parts truck). I had thought that the ends of the axles would ride against the spider-gear cross-shaft, but it turns out that there's supposed to be a "spacer" that sits between the ends of the axleshafts, with the cross-shaft through the middle of the "spacer". The PowrLoc had special spacer "buttons", but of course there's no way to re-use them in the open diff. From what I've read, the bearing design was changed in the later axles, so the spacer wasn't needed. Apparently, it was only needed in the open-diff semi-floaters up through '69 or so, and I've seen very few of our trucks with this rearend setup.
I've spent a lot of time searching the web, and have talked to a couple of drivetrain places in the Palmdale area....no one has one of these or knows where to get the correct part that I need.
Here's a link to close-up view....the number on the part I need is 4294.
http://www.fordification.com/galleries/ ... ?pos=-3573
Can anyone provide any info?
Regards
Regards
Stuck In the Mojave
but my heart's in Idaho!
Dad's 1968 F100 with:
-1972 8100 GVW Axles added
-Power Steering Added
-Power Brakes Added
http://www.fordification.com/galleries/ ... ?album=554
-Power Brakes Added
- heep70
Not on a semi floater D60, not secure enough anyway.averagef250 wrote:Why would the axles be able to move anywhere?
Aren't they held in place with the wheel bearings?
Check with http://broncograveyard.com/ and see what they might have used and laying around.
This might be a tough item to find without buying a complete rearend.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- My427stang
averagef250, the stock axle design used a bearing and a race like half of what you'd expect to see. Basically looks like an outer wheel bearing of a full floater with no corresponding inner.
I have an old axle, I'll get a pic later today
However, I believe you can go to a standard sealed wheel bearing like a 9 inch and not need that piece.
I have not tried it myself, but I was told you can do that. Try at your own risk.
71 F-100 SB 4x4, 461 FE, Edelbrock Pro-flo 4, 4 speed, 4 inch softride lift, all poly bushings, integral PS, most mods installed since the 80's
70 Mustang Sportsroof 489 FE, EFI, TKO-600 5 speed, 4.11s
Engine building by-appointment only--30+ years, specializing in strong street pump gas FEs
I've owned several Ford semi floater 60's and they all used the sealed wheel bearings just like the 9 inches. I always thought IH was the only company that used tapered bearings in the semi floater 60.
I've never seen that spacer piece in a ford. If it was mine I'd figure out a way to run the sealed bearings.
- My427stang
I agree, and its an easy swap. I just have a couple of stock ones laying around from who knows where.
re: Dana 60 Axle Spacer
That single timken setup was truely mickey mouse. You have to
shim the end play. A PITAxx. I got's to work on some O' those.
A floater is mo better.
- basketcase0302
averagef250 wrote:Sounds like 5 minutes with some round stock in a lathe and a drill press would net your part.
True....IF I had access to a lathe and some good-quality round stock. I'm thinking that the material would need to be hardened to some degree, which complicates things.
Part of the issue is that I'm in an VERY isolated location, and the nearest shop of any kind is 50 miles away......at 10mpg and $3.50 gallon, the cost of having a part custom-made would probably be less than the fuel!
Anyway, thanks for the inputs.
tmg
Stuck In the Mojave
-Power Brakes Added
-Power Brakes Added
Re: re: Dana 60 Axle Spacer
I agree. I am VERY pleased with my full-floater.Jake11 wrote:That single timken setup was truely mickey mouse. You have to
Stuck In the Mojave
-Power Brakes Added
-Power Brakes Added
- RedneckTexan
- RedneckTexan
averagef250 wrote:A full floater is a big benefit to a 3/4 ton and up truck that many don't realize. Semi-float rear wheel bearings don't hold up that great especially with good loads on them.
That's for sure....when I was a kid, we used to haul horses and all kinds of other heavy stuff around in that truck with the original semi-floater....my dad went through several sets of wheel bearings, wonder why! I'm MUCH happier with the full-floater, I'm not afraid to pull our R/V anymore.
Stuck In the Mojave
-Power Brakes Added
-Power Brakes Added
