9" questions
9" questions
Ok I found a guy to rebuild my 9" for a price I could afford and now I need susgestions on gears and lockers. I would like to add posi but I am not sure what the best option for my use is. I plan on a 390 or a 460 w/ a c6 with horsepower #'s around the 350-385 at the flywheel and to drive it for fun, maybe head to the track just to see what it is made of. Gas milage is not a concern. I was told maybe a 340 to 360 gear. I would like to hear your thoughts and combs on you own rigs.
1969 F-100 SHORTY W/390 IN PROCESS OF REBUILD
- 71PA_Highboy
re: 9" questions
What size tires?
I would look at 3.7 - 4.11 for tires between 27-32" and 4.56 - 4.88 for anything larger than 35s.
jmo.
Eric
jmo.
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Re: re: 9" questions
Nothing larger than a 30". I just didn't want rev to high with the big block. I am looking at one now thats for sale with the 3.70. Thanks for the post.71PA_Highboy wrote:What size tires?
jmo.
Eric
- F100builder
jmo.
Eric
Patrick
![Image](http://i264.photobucket.com/albums/ii183/F100builder/1969%20F100/P3220011-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/CAXW6TDZ-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan0019-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan-1.jpg)
re: 9" questions
if you plan on much freeway driving, i would probably stick to a 3.50 gear set. it is an all around good set for daily driver and still managable on the freeway. my truck would turn 2800 rpm with 3.50 gears and 27 inch tall tires @ 65-70 mph. Also a factory clutch style posi would probably be the least axpensive and they hold up really well if asssembled correctly. ![2 cents :2cents:](./images/smilies/icon_2cents.gif)
