Ring gear backlash tool
- RedneckTexan
Where can I buy the tool that you use to check the backlash when you change the ring gear? And how do I use it properly
- customcrewcab
re: Ring gear backlash tool
http://store.summitracing.com/egnsearch ... =1&N=700+0
they come with a case too. they have nicer ones but they cost abit more
they are called Dial Indicator
- Wes
I find these are hard to lock down for accurate readings.
Find a solid clean spot on the diff housing to lock your base down. set up dial indicator to read on one of the ring gear teeth as close to 90 degrees from tooth as possible. Hold pinion gear(yoke) move ring gear (by hand) to limit in one direction. Zero dial indicator, move ring gear in opposite direction read indicator. double check every thing.
Moving the ring gear closer to pinion decreases back lash and away from pinion increases back lash. hope this helps.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
Make sure you still have a decent contact pattern in the proper location when you get the backlash set.
Fred
Fred
- RedneckTexan
