Are these uncommon
carcrafter22
Are these uncommon
Post by carcrafter22 »
I already promised these parts to someone so I guess it doesnt matter but I am just curious about them since I dont see them around alot(but then again I never look for them).
I am wondering if they are rare, unusual, sought after, or really common according to the vin they are as follows
1.1967 4spd manual NP-435 trans
2.1967 Dana 60 rear axle with 4.1 limited slip
These came from my 67F100
Any info about them would be great.
Thanks
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
spartman
Post by spartman »
the np435 is one of those common as dirt type transmissions.
The dana 60 might be worth something but I dont know.
FORDification
Site & Forum Admin
Site & Forum Admin
re: Are these uncommon
Post by FORDification »
The transmission is virtually indestructible, but because they made so many of them they're not really that hard to find, for the most part.
The rearend itself is also pretty common...all F250s had them. However, a majority didn't have limited slip, so it's worth a few more bucks....well, at least the carrier.
averagef250
Post by averagef250 »
A semi-float D60-2 with a power-loc and 4.10's is about the most desireable 1/2 ton axle you can get. They fetch $400+ in working shape around here.
FORDification
Site & Forum Admin
Site & Forum Admin
averagef250 wrote:A semi-float D60-2 with a power-loc and 4.10's is about the most desireable 1/2 ton axle you can get. They fetch $400+ in working shape around here.
Whoops....dammit, did it again. I answered a post without completely reading it first. :oops: Yes, a 5-lug Dana 60 is very desirable and very rare. Interestingly enough, every one I've ever run across is limited slip (all three of them! :P ), but yours is the first one that I've heard of that didn't have 3.54 gears in it. I've got one of these in my '67 as well, it came from a highly-optioned '68 Ranger.
carcrafter22
oh I forgot how do I dentify the rear axle? I am assuming its a D60 by looking at the vin tag.
FORDification
Site & Forum Admin
Site & Forum Admin
An F100 will either have a 9" Ford rearend or the 5-lug Dana 60. A Dana 60 has a removable rear cover, the 9" pumpkin removes from the front.
I have also heard of the Dana 44 occasionally showing up in these trucks. To distinguish between a Dana 44 and a Dana 60, look at the housing web. Here's a picture I took when I found my 5-lug Dana 60:
averagef250
Some of the F-100's got Dana 44's as well. If your truck was a six truck I highly doubt it had the Dana 60. I've only seen the 60 in 360-390 trucks.
carcrafter22
The previous owner said it was a dana 44 but the vin plate says dana 60 code E5 so I am curious about it, but yes it is an original 6 cylinder.
dolinick
Post by dolinick »
After reading this thread I remembered the differential looked kind of funny on the '67 I just bought and this morning I looked at it and apparently it is a Dana 60 too. I don't know the gear ratio though.
2003 7.3L F250
1968 F500 Utility Truck
1971ford
Re: re: Are these uncommon
Post by 1971ford »
dolinick wrote:After reading this thread I remembered the differential looked kind of funny on the '67 I just bought and this morning I looked at it and apparently it is a Dana 60 too. I don't know the gear ratio though.
you can find out the ratio from the door tag if the rearend hasnt been changed or the pumpkin tag if the gears havent been changed.
-Ryan
Redcap
Post by Redcap »
Or by spinning the pinion and seeing how many times the wheel or hub turns if you don't trust either of those sources.
