my 72/69 f100
SteveC
my 72/69 f100
Post by SteveC »
OK i thought since i got this far with the 70 and 72 combination i figured ill just put all this into one thread so im not trying to update different ones
Here is were i got them
http://www.fordification.com/forum/view ... highlight=
and where i made the the decision that the 70 was FAR to rusted to try and save when the 72 one was 3 spots of rust and they are minor
Ok and most most recent stuff
got the Stuck 360 out of the 72 and found out why it was stuck
Got the cab off and Dad taught me how to run a cutting torch so we can make a trailer frame to trade the guy for the 83 f100
That is all i have right now. All that is left of the 70 is a rolling frame and a few small parts
ill usally try to update on fridays if i remember my camera
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
67mann
re: my 72 project
Post by 67mann »
:thup: Looks like a good way to pick the cab(chainfall--wish I had the room)with out messin anything up.
SteveC
re: my 72 project
Post by SteveC »
ya the chain hoist is nice and it can rotate to about any where in front of the shop. It is very useful to get the cab and box off of the frame
1967 f-100 4x4
71Ford100
re: my 72 project
Post by 71Ford100 »
I need to get our chain hoist set up in the shop now that we actually have room. Looking forward to updates.
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
SteveC
re: my 72 project
Post by SteveC »
just waiting to add the transmission from a 80's f150 it is either a T170FT (Code-RTS) toploader with over drive or a T-19 not sure which.
When i get the transmission out next week then i can get to finding out which flywheel i need and once i get all the clutch and transmission ,exhaust work done to the frame i can start adding the body back on.
What also helps beside a chain hoist is dads case tractor with the front loader..makes removing engines and hauling parts around the property out of the way a breeze
1967 f-100 4x4
SteveC
re: my 72 project updated (7-9-08)
Post by SteveC »
Ok scrapped the t170 series transmission idea...to hard to get parts and such. I there for have moved on to luckly find a m5r2 5 speed overdrive Transmission. They didnt have the clutch assembally unfortunattly so i ordered a whole new kit from NPD...figured might as well get the new kit that way im not pulling the transmission later to have to replace it.
So if i got that ordered right that just leaves the flywheel to find.
I need to pull the c-4 that is on there now and find out which one i need and then start hunting. why in the world ford made it this complicated :?
Finally getting one step closer to getting this thing back together..
Anyway a few pics of my new found toy
1967 f-100 4x4
SteveC
re: my 72 project updated (8-6-08)
Post by SteveC »
ok got the frame down to just a rolling frame and got most of the grease scrapped off and then power washed off. I also got it loaded up to be taken in and sand blasted.
all loaded and ready to go
1967 f-100 4x4
SteveC
Re: my 72 project updated (8-6-08)
Post by SteveC »
ok dad has been busy in the few weeks that i havent been able to go up to help.
Frame painted, the engine and transmission put together, and put into the frame.
Need to find the slip yoke correct for the m5r2 transmission since i dont have one.. redo all brake lines and hardwear, get a final decision on which fuel tank to use. Get all the wiring to the engine hooked up and the fuel pumps bought and put on. and start adding body back on and get the hydolic clutch hooked up.
1967 f-100 4x4
rjewkes
Post by rjewkes »
good progress.
Did your c4 have the kickdown/passing gear rod? i forget if i asked before.
SteveC
Post by SteveC »
no it didnt come with one
1967 f-100 4x4
67mann
Post by 67mann »
Hey Steve--is your dad lookin for another kid :? :D :lol: :lol: :hmm: I'd even fly'm up here to work on the 70 while I'm at work :P
Good work--lookin good :clap:
Ranchero50
Post by Ranchero50 »
How are you going to do the hydraulics? Check out my project page for pics how I ended up doing mine. The firewall isn't very strong in these things so I had to reinforce it a lot. Project looks really good though.
Jamie
SteveC
Post by SteveC »
i have one idea i got for avaragef250(spelling???) but ill check yours out as well... im up for any good ideas.
and to bad i didnt bring my camera yesturday we got the drive shaft all installed.... we accually had enough parts laying around to make one fit with out having to cut a thing... just a few new u joints and a trip to the pasture for the correct slip yoke and it all fit.
1967 f-100 4x4
SteveC
Post by SteveC »
wow been forever since i updated this... not that ive been able to do anything update worthy till recently
thou with the pictures i can see just how much i missed painting and the primer shows through.... just have to por 15 it later
cab ready to be bolted down after rust fixed and por-15 brushed on.
other parts por-15 and ready to be put on along with a top shot of the custom built gas tank(holds around 24.3 gallons)
Fuel pump (low pressure) and fuel accumulater/filter mock up started
Floor inside por-15 and been working on mock up of newer style dash... also found out that the 91's factory radio will fit in the dash with no major mods... the tabs are still there if i every would want to go back to the 70's style radio
think that this is about all for now. Got some wiring ahead of me nothing to major... expect for the ignition wiring that has me a bit confussed for the molent... but with some help from some of the more electrical incligned people here that has been coming along better.
i Just really want to hear this thing run.
thanks for reading
1967 f-100 4x4
papabug71
Re: my 72/multi year truck project(1-3-09)
Post by papabug71 »
Its lookin' good! You guys have a nice shop. Its cool your dad is helping you with it.
Im going to be keepin check on your progress! :pop:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
