Harbor Freight Engine Stand
- bjde0b
I need a one time use engine stand. Will this 750 lb. stand work for a 302? I am not doing a lot of work. Deconstruct. Clean. Paint. Reconstruct. Motor has max 20,000 since last rebuild to provide justification.
http://www.harborfreight.com/cpi/ctaf/d ... mber=32915
Check out my build. http://s1088.photobucket.com/albums/i336/MyF100/
- kaptnkaos
Re: Harbor Freight Engine Stand
That one will do the job...
Check on craigslist.. I picked up one for $15
Someone had bought it HF for a one time use and wanted to get rid of it ...
KaptnKA S
KaptnKA S
- wickedinhere
It should work fine i just bought one from harbor freight but it was the 1000lb capacity with 4 wheels and its pretty well built and sturdy.
You can pay more but you cant buy better.
- DuckRyder
While that one will do the job, I's spend the extra 10.00 for the 1000 lb one with 4 wheels.
If you get that engine stand, in the hole where the plate slides in to rotate, fill that pipe with some wheel bearing grease and it'll turn really nice.
- F100builder
Something so incredibly simple yet so very helpful!!! That definitely falls under the 'why didn't I think of that' category! I've got 3 engine stands all with motors and do a little prayin' (@#$%! !@#$!!!) every time I have to rotate one of them! Good tip!oldschoolrods wrote:If you get that engine stand, in the hole where the plate slides in to rotate, fill that pipe with some wheel bearing grease and it'll turn really nice.
Patrick
- F100builder
Oh, one more thing...if you don't need it right NOW then wait and check the sales fliers as those things go on sale a lot. I've seen the 750# one go for $29.99 several times in the last year.
Patrick
- thebannister8
sign up for their mailing list ( hf&t ) and get % off coupons by email....i printed a 20% coupon yesterday and it took 6 bucks off my tile saw blade ....
- bjde0b
I got the 1000 lb stand for $50. I wish I would have done the grease thing because it sucks rolling it. I set the engine on cinder blocks once to unbolt the stand and remove the bell housing cover plate. I will do that again so I can grease the cylinder. I borrowed a neighbor's cherry picker so I can't just hand the engine again.
I wish I could claim this as my own but I bought my engine stand this way. The guy I bought it from had drilled and tapped the outer tube for a grease fitting. I don't have to remove the engine to grease it when it gets hard to turn. It apparently hasn't hurt it too much it held my 460 for several years like that, and it is nice when things don't turn as well as it should hit it with a grease gun and yowsers it works again. Just a thought. Tom
