from beginning to end!"Project: Big Nell"(11/1/07)
rjewkes
Post by rjewkes »
oh hell yes1 way to go.
layedout72
Post by layedout72 »
you have NO idea how relieve i am! it sounds SOOOOO BAD ASS in the cab, and out back. we couldnt figure why it sounded supercharged to hell and back..........carb spacer!!! was sucking a TON of air! got it plugged and it cut sound/roughness and over all everything down so much it sounds like a mustang gt or something. im loving it!
69CSF250
re: from beginning to end!"Project: Big Nell"(11/1
Post by 69CSF250 »
Excellent! that brought back memories of a 79 extended cab 250 4x4 i had. I remember being nervous turning the key for the first time. I spent a lot of time and money on it I didn't want to do something wrong. it wouldn't start due to the dizzy being 180 out fixed that and it roared to life. I couldnt stop smiling all day... making good progress there keep it up sounds good too!!!
layedout72
alllllright. this is probably more of a relief than starting the motor! i believe I have my electrical problems beat. it wouldn't charge the battery as some of you know. Well, after messing with it just once more today, it is CHARGING!!!! it sits right around 13.5 or so, but I think running it a while will get it to come up a few more tenths to where it should be.
marz68
Post by marz68 »
that's good to hear man
things are starting to come together now :thup:
layedout72
yep, im starting to figure out where im going to get my s10 clip from as well. Buddy down in florida has one I may pick up while im down there for new years. Then it's time for the frame build :)
marz68
Post by marz68 »
sweeeeet!
There is a sonoma that was rolled parked in front of a house that is 6 houses away from mine and every time I drive by it I think of you cause I remember that your looking for one but then I think of how much it would cost to ship that to you $$$$. :doh: :no:
layedout72
yah, it sucks. around here people drive them until they die, and then fix them until the die again, and the cycle never ends.
i thought i found one, but that went to the crapper. you would think it wouldn't be all too hard.
layedout72
as luck would have it (no really...its good) the truck sits around 14.1 now at idle, and higher with rpm's up. woohoo.
i also just ordered a couple viair 480 compressors (200psi) and a KP Component dual needle gauge.
layedout72
Re: from beginning to end!"Project: Big Nell"(11/1/07)
wow.....a full year and then some with no posting in here. That's not good.
I may be back around though, as fate would have it no one bought my truck (1600 obo) and I come back one day and someone has thrown a crown vic suspension under the front of a bump. So I am up on money a little bit here with taxes coming back and I think my dad is willing to help...So you may be seeing pictures of my bump becoming closer friends with the ground.
I want a 4/6 or 5/7 drop on the truck with mustang 5 spoke 18's. I want to tuck the tire and a little wheel, and that will be the perfect height. I want to put either a 4 link and basic bag setup for towing or drop it with leafs and install some helper bags. Either way, I am also having my toyota built, and I want to tow it with my bump.
Do you guys want pics of my toyota as well? I will make a few posts dedicated to it so this thread doesnt relapse into hibernation if you guys want them.
marz68
Post by marz68 »
Holly sh%$ your back!
Been a while.
Good to hear you will be moving forward on your project!
layedout72
I never left, just lurked a while, no real reason to post until now. Let's hope things work out with the price for the work and parts and we can get this sucker back on the road.
I need:
Crown Vic crossmember and suspension
Driveshaft (probably just have one made?)
Column Shift Bushings
18" mustang gt wheels (08 i believe they are)
Guages of some sort, original or aftermarket
Throttle linkage for 302/stock carb
Floor pans
Cab mounts
ares360
Post by ares360 »
Hope you get it done...don't tell anyone talk you out of doing anything...that seems to happen a lot here. :nono:
Good Luck :hd:
Kane
1971 Ford F250 4x2, no engine.....what am I going to do?
layedout72
ares360 wrote:Hope you get it done...don't tell anyone talk you out of doing anything...that seems to happen a lot here. :nono:
Good Luck :hd:
it's my truck ;)
I have like 500 bucks to go towards this so I should get moving soon. It seems to be not that difficult, but I am not going to do it in my garage, I don't have the room nor the patience.
Does anyone want to see what I have been up to as far as my little toyota I asked about a few times in the motor forum?
mljjones67
Post by mljjones67 »
Glad to have you back layedout72. Good plan on the on the suspension upgrades. It looks to be working out for several here! No one will flame ya for that!!
Good luck and lets see some pics of all you done to both vehicles!
I think ares360 is upset because of the good advice he got on his build. But to each his own.
