Rustoleum paint job
dablack00
Re: Rustoleum paint job
Post by dablack00 »
Thanks. I've been enjoying watching your vici swap. I like the old FE with the vici front end. Cool.
About the body work, yeah, just like I said above, half of my poor body work is because I didn't take it down to metal. The other half is not using a high build primer and then blocking it smooth. If this wasn't my daily driver I would have done those two things and it would have been perfect.
The reason I went with rustoleum is for the ease of touch ups and for the price. I had pretty much everything I needed except for paint. So it was a pretty easy choice. Either go with rustoleum for less than $200 or go all out and spend $1k on the good stuff. The good stuff is nice but when I see a really perfect BC/CC job on an old truck, I kind of don't get it. I use my truck as a truck and I'm rough with it. I wanted something clean and easy to keep up with. If I rub the side of the truck with something I will be able to rough it up with some 400 grit and spray on a couple of coats and buff it out. No big deal. It takes a good bit of time to fix a BC/CC job.
After seeing it in the final stages, I feel pretty good about using it on my next project.
Also, a really shiney BC/CC job looks sort of wrong on a classic. I know I'm in the minority but a rustoleum paint job looks more original to me. I feel the same way about other classics. They just don't look right to me in BC/CC.
jwh f-100
Post by jwh f-100 »
Looks great. Thanks for all the tips. You sure have my attention..
One question, Do you see any reason a rustoleum paint with metalic couldn't be sprayed??? The "roller" guys say metalic paint can't be used but I don't see why it can't be sprayed..
Jason
marvin2
Post by marvin2 »
First off, the truck is looking great man...good job and thanks for the write up and pics!
Got some questions:
1. There still seems to be some gloss with the rustoleum paint (obviously not as much as with a bc/cc). Does this gloss just ware off with time? What if you kept it waxed?
2. You mentioned you were running a 220v compressor, but what size is it....how many gallons?
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
dablack00
Post by dablack00 »
jwh f-100 wrote:Looks great. Thanks for all the tips. You sure have my attention..
Rustoleum is a single stage paint and not any different (in the way it goes on) than other single stage paints. If paint manufactures sell single stage paint that is metalic, then I can't see why you can't add metalic flakes to rustoleum. I would buy a small sample of the metalic flakes, mix it with a quart of rustoleum and spray and old hood to see how it looks.
dablack00
Post by dablack00 »
It is just plain old generic rustoleum. Same stuff you get a home depot or Ace hardware.
marvin2
Post by marvin2 »
Thanks for all the info, dablack00.
dablack00
Post by dablack00 »
Small update.
I wasn't able to put another coat of paint on due to rain but I have knocked down the small run with 360 grit wet and then did a light sanding with 400 grit wet all over the truck. I had some small dust nibs and a couple of moths flew into it. The 400 grit really smoothed stuff out without taking off too much paint. 600 grit would have probably been better but I didn't have any and I'm not spending another penny!
We will see how it looks after the next coat and I might stop there. I want to make sure I have enough paint on the truck so I can lightly sand it with 1500 or 2000 grit wet paper and then buff it out.
I'm hoping I will be able to put on another coat today after work (6:45 ish).
Tank
Post by Tank »
Looks great so far! I had bought one of those HF purple guns a while back cause I wanted to learn how to paint. It's nice to know that it works ok. Keep those pics coming! Thanks
I'll keep my FREEDOM, my GUNS, and my MONEY. You can keep your CHANGE!
dablack00
Post by dablack00 »
Well today after work, I put on the final coat. It looks good so I'm going to leave it at that. I did get a couple of runs again, but I will carefully sand them out and buff it up.
I'm going to wet sand with 2000 grit and try some buffing this week. I will get some pictures up if it buffs out nice.
Then I will start assembly.
FormerMarine1981
Post by FormerMarine1981 »
Looks good, now that you have practiced on yours I will bring you the cab I got from California and you can work on it for me :thup: :D :evil:
mrsnicks
Post by mrsnicks »
FormerMarine1981 wrote:Looks good, now that you have practiced on yours I will bring you the cab I got from California and you can work on it for me :thup: :D :evil:
But... but.... He said I was next.....
:cry:
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
FormerMarine1981
Ok Patrick, if you can beat me there you can go first.... If he says yes. Austin I thought you were going to paint the truck Black?? what happened?
marvin2
Post by marvin2 »
MORE PICS!!!!!....please.
69timemachine
Post by 69timemachine »
It is looking good! We do need more pics though! :thup: :thup:
Jason
'06 Mustang GT 5-speed
jwh f-100
Post by jwh f-100 »
Cool thanks,, Actually I am thinking of using a rustoleum color with metalic, "aluminum". The roller guys can't use it but I bet it would spray nice...
Jason
