I have a few random photos from today that I thought I'd put here for your amusement. There's not much of a story behind these, but I figured they might be entertaining!
http://www.robroygregg.com/Number50/IMG_4124z.JPG
Thanks for looking!
Robroy
Hey Fordman thanks for replying! You're right--it's backwards! I hadn't noticed. I'll be sure to spin it around before bolting it in place. At the moment it's a gravity fit.fordman wrote:oops spin that battery around. or get some longer cables.
Thanks Td!!!td wrote:as usual, great pics!
Thanks, but you might be disappointed. Photos have a mysterious way of making things look better than they are--or perhaps it's simply that I don't post high resolution photos of all the rust holes!td wrote:i wish i could give your truck a good look in person, seems you have a great eye for detail much like myself![]()
You got it! I originally planned on working on the truck for 2 to 6 weeks, and so far it has been one year and four months! Each layer I peeled off of the onion exposed funky stuff that I couldn't bear to accept. Before this project, I was amazed when I heard that guys sometimes spend five years or more restoring a car; now I understand completely.td wrote:i know you can't wait to spin that thing down the road after all the hard work and $ you've invested.
Thanks! After I'd already picked that out one, I read some forum posts saying that they think K&N filters are excessively free-flowing, to the point of letting too much dirt in to the engine. But in the absence of stronger evidence I'll just leave it as-is.td wrote:p.s. i love the air cleaner!!
Your wish is my command! I'll take some tomorrow and post them here. I don't have any full perspective photos of the entire bay at the moment.td wrote:p.s.s. could you take a couple overall shots of the engine bay and post'em in this thread for me?
Hey Josh! Yeah, the idea of rust-free operation sold me right away. Most old vehicles I've seen have been eaten alive by their batteries, at least to some degree.Joshpow wrote:Nice! I just got a red top in mine. A hand me down from my old dakota! Great batteried though. Especially for lack of corrosion. Big help for these trucks.
Hi Ximy! Thanks! I bought this Yellow Top (part# ULT-9042-218) from Summit for $189.95, plus $11.95 shipping = $201.90 total. The Red Tops are slightly less expensive, and have greater (C)old (C)ranking (A)mps, but aren't as fond of being severely discharged as the Yellow Tops are. The Red Top is probably the best choice for most trucks, especially if you live somewhere with cold winters! And (sometimes) Costco has Red Tops in stock.ximy wrote:Looks good... I'm gonna need a battery soon... how much do those cost?
Hey Bill! That sounds like you got a great deal!fireguywtc wrote:I paid 125 a year ago for a red top, had a cupon though. They range a little but thats pretty close. I think yellow tops cost a little more.
I know exactly how that goes! I've had that happen with nearly new batteries a few times in different cars.fireguywtc wrote:Bad part is about a month after I bought the battery is when my engine got bad enough that I decided to start tearing it all apart. I recently donated the red top to my volly dept.
Thanks very much for pointing this out! In my case, the engine was actually broken in at the engine builder's, so I'm OK there! I investigated this situation at the time also, and heard that the header finish can be damaged by bits of engine assembly lube that get shot out the exhaust ports, then catch on fire inside of the headers. That creates an extreme hot spot that can really mess up the finish.td wrote:Just something i thought of looking at our pics here. i don't know what manufacturer made your headers but mine are headman and they along with some other companies recommend that you not do initial engine starting (break-ins) with coated headers. the temps of the constant prolonged higher RPM'S combined with no movement (airflow) to cool the engine bay can damage the (non-cured) coating and cause it to fail prematurely. the info that came with my headman's said if you have to do it to at least use a fan to move some air threw the engine bay. i just used a set of manifolds and swapped the headers in after my break-in.the idea here is the coated headers need normal driving conditions that create lower temp, gradual heat up and cool down cycles to properly cure the coating before their subjected to extreme heat =(heavy left foot driving)
Indeed, and thank you. I really appreciate your advice! If my engine hadn't been broken in yet, I could mess up an expensive set of headers (mine are Hedmans also).Td wrote:p.s i say all this not knowing if your engine is newly assemgled and needing a break-in, if it is this could be good info for ya!
I'm not sure about perfection, but it should be a very fun toy to take around the block!Joshpow wrote:#50 is on its way to perfection looks like!
So far it's working out perfectly! I did away completely with the external voltage regulator and drastically simplified the alternator harness to match. I'll post a photo of that harness modification if you're really curious about what I did. It wasn't strictly necessary, but it removed about 90% of the wiring in the harness that wasn't being used anymore (since my new alternator has an internal regulator).Joshpow wrote:How is the one wire alternator change working out ?
That's a good question, and I'm not able to answer it fully. I'm sure it's possible, but I'm not sure whether it's feasible or not.Joshpow wrote:I like the idea, but I'd like to keep my factory gauge intact and possibly functional. Do you think that is possible?
Hey Patrick! I'd be happy to post a photo of that and an explanation of what I did. I'll do that pretty soon here. The modification isn't necessary for the 1 wire alternator to work, but it does simplify the wiring in the area a huge amount.mrsnicks wrote:I'd like to see pics of the harness modification for the 1 wire alternator hookup.
Good observation! At the moment I'm having other issues with the build that prevent me from needing a hold down quite yet! But I'll definitely strap it down good before hitting the bumpy road!mrsnicks wrote:Are you not going to use a hold-down on the battery?
