Tomorrow I will make my first attempt to start the engine. It'll all be captured on video.
http://www.robroygregg.com/Number50/IMG_4137z.JPG
Robroy
How did you know I'd be sweating?1967AceStroker wrote: Tomorow night I'll be checking for that sweat engine start-up.
Uh, I was correct through my misspelling? I meant sweet,robroy wrote:How did you know I'd be sweating?1967AceStroker wrote: Tomorow night I'll be checking for that sweat engine start-up.
Robroy
Indeed! This was especially thrilling to me since this is the first high performance engine I've ever played with.Fordnatic wrote:Starting up a new rebuild is always a thrill!! I'm glad it went well.
Gosh that's smart! How do you pressurize it? Using compressed air? Sounds a little scary to mix that with a bunch of gasoline, but maybe it's not too dangerous.Fordnatic wrote:I always stuck a rag around a blow nozzle in the gas tank and pressurized the system until the float bowls were full-to avoid the cranking.
Thanks!!!Fordnatic wrote:Again, congrats!!
That sounds like something exciting to anticipate! That's a long time to have such a nice engine uninstalled.1967AceStroker wrote:Nice, glad all went well for the start-up. I get to do the same with my 351C, its at the engine shop right now getting check-up. It only made a few dyno runs, and thats it. Hasn't been run in 20+ years, it was going in a race car that never happened.
Thanks for the appreciation! When I'm able to, and despite my inexperience with cars, I try to make re-usable posts. I try to make the types of posts I always want to find when I'm trying to figure something out!1967AceStroker wrote:It always amazes me how detailed you describe everything, and how many detailed clear pictures you put on. Looks like your great attention to detail shows in your work too.
Yes it worked OK, although the 1/4" socket was a little thick. You know the cylinder that the distributor drive shaft is recessed in? The socket barely fit in there. A skinnier socket would have been better.Fordnatic wrote:I didn't think of using a 1/4" extension, looks like it worked well.
That sounds like a smart method! It also sounds like you've gone down this road a few times before! It was a completely new experience for me. I can imagine that a part of an old distributor would be easier to use.Fordnatic wrote:I gutted an old distributor and used the shaft from that for my pre-oiler. I guess one advantage is there is nothing to fall in that way.
Okay, this is good to know! I wasn't sure if my trouble there was an artifact of my personal lunacy.Fordnatic wrote:On your timing issue-I usually have to bump (turn) the oil pump shaft a couple times before stabbing the distributor just where I want.
Gosh, that sounds like an experienced method that would have never occurred to me! I might try this next time. Although I'd need to brush up on how to get the engine to TDC (I'll look it up). Thanks for sharing this method with me!Fordnatic wrote:You can time pretty accurately by putting the #1 cylinder on TDC. Turn the engine to the degrees you want (i.e. 12 BTDC) then stab the distributor making certain the rotor is pointing at the #1 plug wire and it's just ready to fire. With points you turn the body of the dist until the rubbing block is about on the hump to open the points. With electronic you line up the reluctor wheel with the inductive pick up. I have set timing like this and when checked it with a light later and found it to be very close.
That's an interesting method! Did you learn this from another mechanic or invent it yourself? Seems pretty clever.Fordnatic wrote:Yes, I meant air pressure in the fuel tank. The rag around the nozzle leaks most of the pressure off, you just need a couple psi to get fuel to flow to the carb.
Thanks Fordnatic! Yes it was indeed thrilling! It sure felt different from all the engines I've ever messed around with before.Fordnatic wrote:Again, congrats. I'm a bit jealous as it really is quite a thrill starting one for the first time.
