transmission leak
old ford guy
transmission leak
Post by old ford guy »
just had the transmission on my 67 overhauled, still have a leak around the pan..about half a pint a day looks like the screw on the front right side... replaced screw and gasket tightened down put permatex on the screw but if still leaks any ideas or does anyone know where i can get thicker gaskets
thanks
TNIceWolf
Re: transmission leak
Post by TNIceWolf »
Most likely that is a deformed hole at that screw on the pan. Usually caused from overtightening. What you can do is drop the pan and return the screw holes in it to a more flat configuration by use of a hammer......hammers....or hammer and wood block. Then install a new gasket and see what happens. A cork gasket is the worst gasket for this scenario to happen. But it can be overcome by using the correct torque and tightening pattern on the pan bolts.
Presently in the stable
1969 Ford F-350 DRW
:yt: unless that one bolt hole is stripped out.
big orange
Post by big orange »
Could be just that the pan flange is not flat :hmm:
I cut it twice and its still too short!!
yea thats what we were sayign. the pan might not be flat around the holes for the pan bolts.
big orange
:yt: :yt:
Skifu
Post by Skifu »
One of the reasons I just swaped my e4od to a T-18 is cause it would leak all the time,mine would leak from the cooling lines,but it also leaked from the pan gasket,and nothing you could do would help it,I guess it was worn out when I got the truck.
94 Ford F-150 super cab
300-6 eod auto,changing to NP-435
