460 swap
- big orange
Re: 460 swap
460 swap kits for fox body mustang are pretty common.. I'll see if I can find one on fleabay
I cut it twice and its still too short!!
- big orange
Re: 460 swap
Top pic is for a 460 into a fox body.. do you think it would work in the 4x4 bump???
Bottom is the #11a kit($1,215.52) from LandL this was the one Alan from LandL recommended for my swap
- OldRedFord
Re: 460 swap
Rear sump pan from a van should work, or a 4x4.
I would try bfeveansraceparts.com. See what the price from them is for a rear sump 4x4 pan for a 460.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- BobbyFord
Re: 460 swap
Ford sells a kit for the rear sump pan. Comes with pan, pump pick-up, 1 piece rubber pan gasket, dipstick and tube and the main cap stud to bolt the pick-up to. I just bought one.
