67 2wd to 4wd....
zakt
67 2wd to 4wd....
Post by zakt »
getting ready to pull the 67' F350 2wd front end off...coil buckets and all. I will have all the pieces if anyone is interested in any pieces for a good deal etc. PM me with an offer.. Im in Reno, NV.
heep70
re: 67 2wd to 4wd....
Post by heep70 »
Keep us tuned in.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Heavenlyfire
Post by Heavenlyfire »
Good luck to ya, keep us up to date. I am thinking of that in the future.
zakt
Post by zakt »
The front is removed now onto pulling all the rivets to get the brackets off...
1972 Ford F350 crewcab
zakt
Post by zakt »
Now have my 12" springs mounted on the rear off my 85' using the 85' hangers.. now onto getting the axle perches redone to fit the new springs..
http://www.geocities.com/crewcab1967/
4x4x4crewcab
Post by 4x4x4crewcab »
Hey Todd looking good. We haven't heard from you in a while figured you were busy on the project. Keep up the good work and thanks for the update.
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
69F110
Post by 69F110 »
Looking good. Keep us updated.
Steve Davis
Pastor and U.S. Army Retired
zakt
Post by zakt »
Just bought the new engine towers and motor mounts from L&L to swap the 360 to the 460 motor. I will be using my 95' motor which is EFI and buying a mass air kit from http://www.mass-air.com/Products.htm#Tr ... Air%20Kits using the 80mm mass air with 30lb injectors... with the E40D... just debating now if I want the gear vendors auxilary transmission. I think I might just put it on so I get the length out of the driveline to get away from using the carrier bearing in the drive line....
4x4x4crewcab
460 E.F.I. and E4OD fancy,fancy this is gonna be a nice machine. Thanks for the update
Mark
1999 Ford Windstar
boots
Post by boots »
i wanted to do this with my truck, but never got around to it. Thoes are massive springs!!! keep us posted pls
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
69F110
Post by 69F110 »
Cool stuff.
Steve Davis
zakt
Post by zakt »
I cant find a place that makes a adapter to mate a NP205 transfer case to the E40D transmission... So back to C6 transmission with married NP205 transfer case with the gear vendors auxilary transmission... so more or less I will have overdrive :roll:
Heavenlyfire
Lots of details on the front end swap please, this is something I have been thinking about for a while. I really miss having a 4X4
zakt
Post by zakt »
check out the frame pictures of the 2wd vrs 4wd... crossmembers are different in the front and then looks like the 4wd is boxed where as the 2wd is not... so debating now what to do with that...
http://www.fordification.com/images/sch ... _frame.jpg
zakt
Post by zakt »
Looks like I will use the 2wd engine tower locations and pull the 2wd crossmember and make a better looking custom built one like below...
