More done on the 72'...
zakt
Post by zakt »
more disasembly done, get closer to takin it to the frame shop and starting the leaf front conversion...got some temp 2" blocks on the back with the 33" so looks like maybe doing 8-10" springs with 37" tires. Will actually jack it up and down to check what I like with the real 37" tires before getting the new springs.
1972 Ford F350 crewcab
craftsman
Re: more disasembly done on the 72'...
Post by craftsman »
:thup: good start :clap: What drivetrain you goin with? That truck looks in really good shape.
rattlecan
Post by rattlecan »
Hey Todd,
Looking good! I am anxious to see what 37" look like on your truck. still trying to decide what size to put on mine.
anything worth doing is worth doing in EXCESS!! - Carroll Shelby
70 F-350 4X4 crew
zakt
Post by zakt »
going with c6, married NP205 (with 8 1/2" adapter) with a gear vendors aux trans. Changing the bed out and cutting the cab in half and splicing in a different cab...other than that no problems :lol: (rusted out all over the front) Those are 33" in the picture and thinking those look small and 35" arent much bigger so believe the 37" tires might look about right??
BigBlueF250
Post by BigBlueF250 »
I run 37's on mine in the summer. Looks waaay better than the 35's I run in the winter.
basketcase0302
Post by basketcase0302 »
Todd,
:bow:
That's on my "way down the road wish list"! :thup:
Looking good man.
zakt
Post by zakt »
thought about the E40D with the over drive since I have everything on the EFI and 10.25 rear (VSS sensor) to use it but the main reason is I dont want to run the BW1356 tcase either, to wide and would have to clock it... so the NP205 is the BOM... but on an E40D they say the front drive shaft will hit the case and maybe linkage issues... etc..etc.. so thinking the aux trans is a gear splitter so really 1, 1.5, 2, 2.5,3, 3.5 gears so actually in the long run better. :? I also wont run the mechanical speedo on the trans but use the VSS in the 10.25 so just electric speedo :thup:
dcbullet
Post by dcbullet »
Fantastic garage!
zakt
Post by zakt »
Have a 4 car and still to small... in the works for the future another 1.5 - 2 car on the side of the house (just for the 72 :thup: ) my suburban is in there next to the 72 (open spot in the pic) and the grand cherokee next to that and the jeep wrangler outside (wife not happy about that, thats hers ) so I actually get 3 stalls (when I get the donor truck out wrangler goes back in ..someday :lol: )... so somehow between that I have to get it all to fit :doh: oh then the motorcycle in front of the grand...
zakt
Post by zakt »
well the beds off the 72 and have only room for 1 driveable car in the garage so (2) outside. Going to try to get the 69 (donor truck) apart on the other side of the 72 and clear more space.
1971ford
Post by 1971ford »
Nice!
Is that a 4x4 front frame on the ground or something that is going to aid you in the conversion????
-Ryan
zakt
Post by zakt »
yes, it is a 68 F250 4x4 frame (a piece anyway :lol: ) Using all the brackets and crossmembers on my F350. I also have a 95 F350 frame horn where the power steering box goes and the box so want to use that ....
zakt
Post by zakt »
got the cab off the frame today, jackstand come in handy again :D will build a metal frame under it with casters later... now it is ready to pull out and to the frame shop shortly. I hope to get some pics of it on the frame rack :thup:
zakt
Re: More done on the 72'...
Post by zakt »
got the frame out all by itself and the 69 also all tore down with just parts left on it I need for the 72 (you can see the black 69 bed there behind the 72 cab, on a furniture dolly :D ) here is my current list of todos..
1. get stainless steel fan shroud made for 2) 12" electric fans
2. get radiator dipped and cleaned up
3. send out core support to get dipped, POR15 after
4. fix bent frame horns
brandon.k
Post by brandon.k »
zakt wrote:got the cab off the frame today, jackstand come in handy again :D will build a metal frame under it with casters later... now it is ready to pull out and to the frame shop shortly. I hope to get some pics of it on the frame rack :thup:
[ Image ]
Is that the motor thats going in it? Thats going to be a good looking ride when its done.
